New Nagios XI Install issues.
TimGrz
Post by TimGrz »
System Info:
  • Nagios: Latest Nagios XI as of 21 July 2016
    Manual Install of XI
    OS: Red Hat Enterprise Linux Server release 7.2 (Maipo)
    OS: 64bit?
    OS: Fresh RHEL server iso from RedHat (downloaded 21 July 2016)
    System is registered with Red Hat. yum update prior to Nagios install successful.
./fullinstall unable to download nmap-6.47-1.x86_64. However I can use wget to d/l the file nearly instantly.
<snip>
Total size: 126 M
Total download size: 5.1 M
Installed size: 442 M
Downloading packages:
No Presto metadata available for nagiosxi-deps
http://repo.nagios.com/nagiosxi-deps/7/nmap-6.47-1.x86_64.rpm: [Errno 12] Timeout on http://repo.nagios.com/nagiosxi-deps/7/nmap-6.47-1.x86_64.rpm: (28, 'Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds')
Trying other mirror.
Error downloading packages:
  2:nmap-6.47-1.x86_64: [Errno 256] No more mirrors to try.
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
If I try to install to install nmap-6.47-1.x86_64.rpm manually with yum install nmap-6.47-1.x86_64 or yum install nmap-6.47-1.x86_64 -c I get:
[root@wva-dev-nagiosxi nagiosxi]#  yum install nmap-6.47-1.x86_64
Loaded plugins: product-id, search-disabled-repos, subscription-manager
Resolving Dependencies
--> Running transaction check
---> Package nmap.x86_64 2:6.47-1 will be installed
Dependencies Resolved
 Package                        Arch                             Version                               Repository                               Size
Installing:
 nmap                           x86_64                           2:6.47-1                              nagiosxi-deps                           5.1 M
Transaction Summary
Install  1 Package
Installed size: 18 M
Is this ok [y/d/N]: y
nmap-6.47-1.x86_64.rpm         FAILED
Other info:
Once I hit return there is about a ~15 second pause and wget completes.
[root@wva-dev-nagiosxi nagiosxi]# wget http://repo.nagios.com/nagiosxi-deps/7/nmap-6.47-1.x86_64.rpm
--2016-07-21 16:43:49--  http://repo.nagios.com/nagiosxi-deps/7/nmap-6.47-1.x86_64.rpm
Resolving repo.nagios.com (repo.nagios.com)... 72.14.181.71, 2600:3c00::f03c:91ff:fedf:b821
Connecting to repo.nagios.com (repo.nagios.com)|72.14.181.71|:80... connected.
Length: 5317043 (5.1M) [application/x-rpm]
Saving to: ânmap-6.47-1.x86_64.rpmâ
100%[===========================================================================================================>] 5,317,043   --.-K/s   in 0.06s
2016-07-21 16:44:37 (83.1 MB/s) - ânmap-6.47-1.x86_64.rpmâ saved [5317043/5317043]
[root@wva-dev-nagiosxi nagiosxi]# yum deplist nmap.x86_64 2:6.47-1
package: nmap.x86_64 2:6.47-1
  dependency: python >= 2.4
   provider: python.x86_64 2.7.5-34.el7
[root@wva-dev-nagiosxi nagiosxi]# yum info python.x86_64 2.7.5-34.el7
Installed Packages
Arch        : x86_64
Version     : 2.7.5
Release     : 34.el7
Repo        : installed
From repo   : anaconda
Summary     : An interpreted, interactive, object-oriented programming language
URL         : http://www.python.org/
License     : Python
Description : Python is an interpreted, interactive, object-oriented programming
            : language often compared to Tcl, Perl, Scheme or Java. Python includes
            : modules, classes, exceptions, very high level dynamic data types and
            : dynamic typing. Python supports interfaces to many system calls and
            : libraries, as well as to various windowing systems (X11, Motif, Tk,
            : Mac and MFC).
            : Programmers can write new built-in modules for Python in C or C++.
            : Python can be used as an extension language for applications that need
            : a programmable interface.
            : Note that documentation for Python is provided in the python-docs
            : package.
            : This package provides the "python" executable; most of the actual
            : implementation is within the "python-libs" package.
I hope I provided enough information. :D
Thank you in advance.
/tg
Re: New Nagios XI Install issues.
It could be caused by the yum cache needing to be cleared out.
Try running this command and then try the upgrade again.
yum clean all
Also, is the server behind a proxy server?
TimGrz
Post by TimGrz »
Tried clearing yum's cache both with the above commands posted above and manually,
No proxy.
/tg
When you download the nmap rpm using wget, try using this command to install it. You need to have the .rpm in the filename when installing locally.
yum install nmap-6.47-1.x86_64.rpm
Next, lets rebuild the yum cache by running this command. Then try running the install again.
yum makecache
TimGrz
Post by TimGrz »
XI installed. Please lock thread.
/tg
