Alerting on Null Events
CFT6Server
What is the query or alerting settings to use if I want to alert when there are 0 events over a period of time?
- Box293
- Too Basu
Re: Alerting on Null Events
The threshold settings are based on the Nagios Plugins standard.
https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT
So I believe that @0 should be what you require.
CFT6Server
Thanks. I have configured the alerts with those threshold values. Will monitor this for a bit.
CFT6Server
Thanks Box293. The threshold alert works perfectly as I received notification last night for null events.
Is it alright if we lock this thread and mark the issue as resolved?
