NagiosXI Installation - Login Failed
aap
Post by aap »
Im trying to install Nagios XI on RHEL5 and have been having some problems. The install stops at ./E-importnagiosql with the following error
NAGIOSQL LOGIN FAILED!
ERROR: NagiosQL import appears to have failed - exiting. (Reason: Import files are still present in /usr/local/nagios/etc/import)
Is there something I am missing and has anybody experienced this issue as well? Please post any resolutions you have.
Carin
Re: NagiosXI Installation - Login Failed
Post by Carin »
we are trying to install Nagios XI as well (on CentOS 6) and we are experiencing the same problem. During installation we had other problems too, which was finally solved, but at this point we cannot move further. Any advice?
mguthrie
Post by mguthrie »
CentOS 6 threw some repo changes at us after we released 1.7. Here's our solution that should take care of this issue.
http://support.nagios.com/wiki/index.ph ... n_Problems
