nagios logs
nagios logs
Hi!
Tell me what is it?
How to remove it from the logs?
Solaris OS 11.3, nagios 4.2.1. (4.2.0 on a similar problem)
logs nagios:
[1473421026] Nagios 4.2.1 starting... (PID=18643)
[1473421026] Local time is Fri Sep 09 14:37:06 MSK 2016
[1473421026] LOG VERSION: 2.0
[1473421026] qh: Socket '/opt/nagios/var/rw/nagios.qh' successfully initialized
[1473421026] qh: core query handler registered
[1473421026] nerd: Channel hostchecks registered successfully
[1473421026] nerd: Channel servicechecks registered successfully
[1473421026] nerd: Channel opathchecks registered successfully
[1473421026] nerd: Fully initialized and ready to rock!
[1473421026] wproc: Successfully registered manager as @wproc with query handler
[1473421026] wproc: Registry request: name=Core Worker 18644;pid=18644
[1473421026] wproc: Registry request: name=Core Worker 18645;pid=18645
[1473421026] wproc: Registry request: name=Core Worker 18646;pid=18646
[1473421026] wproc: Registry request: name=Core Worker 18647;pid=18647
[1473421026] Successfully launched command file worker with pid 18648
[1473421108] wproc: Core Worker 18644: job 2 (pid=18669) timed out. Killing it
[1473421108] wproc: Core Worker 18644: job 2 with pid 18669 reaped at timeout. timeouts=1; started=3
[1473421116] wproc: Core Worker 18646: job 2 (pid=18671) timed out. Killing it
[1473421116] wproc: Core Worker 18646: job 2 with pid 18671 reaped at timeout. timeouts=1; started=3
[1473421118] wproc: Core Worker 18644: job 1 (pid=18663) timed out. Killing it
[1473421182] wproc: Core Worker 18644: job 4 with pid 18679 reaped at timeout. timeouts=4; started=7
[1473421193] wproc: Core Worker 18646: job 4 (pid=18682) timed out. Killing it
[1473421193] wproc: Core Worker 18646: job 4 with pid 18682 reaped at timeout. timeouts=4; started=7
......continue indefinitely
Nagios it works, send messages and SMS. But it strongly loads the logs.
I guess that it is responsible for survey services.
Tell me what is it?
logs nagios:
- Box293
- Too Basu
Re: nagios logs
Do you have any services that are currently timing out?
Re: nagios logs
No i have not. This is the default setting .
[/url]
[/url]
[/url]
[/url]Re: nagios logs
And so after any check any host
nagios log:
[1473680737] wproc: Registry request: name=Core Worker 1607;pid=1607
[1473681150] wproc: Core Worker 1607: job 1 (pid=1629) timed out. Killing it
[1473681150] wproc: Core Worker 1607: job 1 with pid 1629 reaped at timeout. timeouts=1; started=2
nagios.debug 16
** Handling check result for service 'SSH' on host 'localhost' from 'Core Worker 1607'...
[1473681150.189284] [016.1] [pid=1135] HOST: localhost, SERVICE: SSH, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 0, OUTPUT: SSH OK - Sun_SSH_2.2 (protocol 2.0) | time=0.003292s;;;0.000000;10.000000
[1473681150.189295] [016.1] [pid=1135] Service is OK.
[1473681150.189300] [016.1] [pid=1135] Service did not change state.
[1473681150.189307] [016.1] [pid=1135] Rescheduling next check of service at Mon Sep 12 14:56:30 2016
[1473681150.189315] [016.0] [pid=1135] Scheduling a non-forced, active check of service 'SSH' on host 'localhost' @ Mon Sep 12 14:56:30 2016
[1473681150.189331] [016.1] [pid=1135] Checking service 'SSH' on host 'localhost' for flapping...
[1473681150.189336] [016.1] [pid=1135] Checking host 'localhost' for flapping...
[1473681156.975753] [016.0] [pid=1135] Starting to reap check results.
nagios log:
nagios.debug 16
Re: nagios logs
When you see the error in the log file. take a note of the PID that generated it and then post that information from the nagios.debug file that matched the PID number.
That should show us the check that is timing out.
Re: nagios logs
Informational Message[09-13-2016 10:15:42] wproc: Core Worker 1291: job 1 with pid 1363 reaped at timeout. timeouts=1; started=2
Informational Message[09-13-2016 10:15:42] wproc: Core Worker 1291: job 1 (pid=1363) timed out. Killing it
Informational Message[09-13-2016 10:15:13] wproc: Core Worker 1290: job 1 with pid 1344 reaped at timeout. timeouts=1; started=2
Informational Message[09-13-2016 10:15:13] wproc: Core Worker 1290: job 1 (pid=1344) timed out. Killing it
Informational Message[09-13-2016 10:12:54] Successfully launched command file worker with pid 1294
Informational Message[09-13-2016 10:12:54] wproc: Registry request: name=Core Worker 1293;pid=1293
Informational Message[09-13-2016 10:12:54] wproc: Registry request: name=Core Worker 1292;pid=1292
Informational Message[09-13-2016 10:12:54] wproc: Registry request: name=Core Worker 1291;pid=1291
Informational Message[09-13-2016 10:12:54] wproc: Registry request: name=Core Worker 1290;pid=1290
Informational Message[09-13-2016 10:12:54] wproc: Successfully registered manager as @wproc with query handler
Informational Message[09-13-2016 10:12:54] nerd: Fully initialized and ready to rock!
Informational Message[09-13-2016 10:12:54] nerd: Channel opathchecks registered successfully
Informational Message[09-13-2016 10:12:54] nerd: Channel servicechecks registered successfully
Informational Message[09-13-2016 10:12:54] nerd: Channel hostchecks registered successfully
Informational Message[09-13-2016 10:12:54] qh: core query handler registered
Informational Message[09-13-2016 10:12:54] qh: Socket '/opt/nagios/var/rw/nagios.qh' successfully initialized
Informational Message[09-13-2016 10:12:54] LOG VERSION: 2.0
[1473750913.000681] [12288.1] [pid=1289] ## Polling 974ms; sockets=6; events=12; iobs=80fe1a0
[1473750913.417872] [064.1] [pid=1289] Making callbacks (type 2)...
[1473750913.417886] [12288.1] [pid=1289] ## Polling 557ms; sockets=6; events=12; iobs=80fe1a0
[1473750913.418016] [001.0] [pid=1289] handle_async_service_check_result()
[1473750913.418031] [016.0] [pid=1289] ** Handling check result for service 'Root Partition' on host 'localhost' from 'Core Worker 1290'...
[1473750913.418037] [016.1] [pid=1289] HOST: localhost, SERVICE: Root Partition, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 0, OUTPUT: DISK OK - free space: / 7760 MB (68% inode=99%);| /=3642MB;9122;10262;0;11403
[1473750913.418047] [001.0] [pid=1289] get_service_check_return_code()
[1473750913.418053] [016.1] [pid=1289] Service is OK.
[1473750913.418058] [016.1] [pid=1289] Service did not change state.
[1473750913.418064] [016.1] [pid=1289] Rescheduling next check of service at Tue Sep 13 10:19:13 2016
[1473750913.418070] [001.0] [pid=1289] get_next_valid_time()
[1473750913.418076] [001.0] [pid=1289] _get_matching_timerange()
[1473750913.418082] [001.0] [pid=1289] schedule_service_check()
[1473750913.418087] [016.0] [pid=1289] Scheduling a non-forced, active check of service 'Root Partition' on host 'localhost' @ Tue Sep 13 10:19:13 2016
[1473750913.418093] [001.0] [pid=1289] add_event()
[1473750913.418099] [064.1] [pid=1289] Making callbacks (type 13)...
[1473750913.418105] [064.1] [pid=1289] Making callbacks (type 6)...
[1473750913.418110] [064.1] [pid=1289] Making callbacks (type 13)...
[1473750913.418115] [001.0] [pid=1289] check_for_service_flapping()
[1473750913.418120] [016.1] [pid=1289] Checking service 'Root Partition' on host 'localhost' for flapping...
[1473750913.418125] [016.1] [pid=1289] Service is not flapping (0.00% state change).
[1473750913.418131] [001.0] [pid=1289] check_for_host_flapping()
[1473750913.418136] [016.1] [pid=1289] Checking host 'localhost' for flapping...
[1473750913.418141] [016.1] [pid=1289] Host is not flapping (0.00% state change).
[1473750913.418147] [12288.1] [pid=1289] ## Polling 556ms; sockets=6; events=13; iobs=80fe1a0
[1473750913.418227] [064.1] [pid=1289] Making callbacks (type 2)...
I could not find records with a pid 1344.
Record appropriate time indicated above
Tell me what kind of settings affect the timeout?
debug.txt- (106.89 KiB) Downloaded 202 times
Re: nagios logs
Edit your nagios.cfg file and update the following logging options to enable them and then restart the nagios process.
This should populate the nagios.log file with the command that is causing the timeout and then you can see what is causing the timeout and you can fix the issue.
Most plugins have -t option to set the timeout for when the plugin is ran so you can set that to be shorter than the host/service/notification/event_handler timeout settings in the nagios.cfg file and then those log entries should go away.
log_event_handlers=1
log_external_commands=1
log_host_retries=1
log_notifications=1
log_service_retries=1
Re: nagios logs
It is written in nagios.conf .tgriep wrote:Code: Select all
log_event_handlers=1 log_external_commands=1 log_host_retries=1 log_notifications=1 log_service_retries=1
PID does not write in the logs . Looked processes associated with nagios
root@nagios:/opt/nagios/var/spool# ps -ef | grep nagios
root 1577 13 0 17:20:34 console 0:00 /usr/sbin/ttymon -g -d /dev/console -l console -m ldterm,ttcompat -h -p nagios console login:
root 832 13 0 16:36:25 vt/4 0:00 /usr/sbin/ttymon -g -d /dev/vt/4 -l console -m ldterm,ttcompat -h -p nagios vt4 login:
root 822 13 0 16:36:25 vt/5 0:00 /usr/sbin/ttymon -g -d /dev/vt/5 -l console -m ldterm,ttcompat -h -p nagios vt5 login:
root 821 13 0 16:36:25 vt/3 0:00 /usr/sbin/ttymon -g -d /dev/vt/3 -l console -m ldterm,ttcompat -h -p nagios vt3 login:
nagios 9439 9426 5 14:31:11 ? 24:54 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
root 824 13 0 16:36:25 vt/6 0:00 /usr/sbin/ttymon -g -d /dev/vt/6 -l console -m ldterm,ttcompat -h -p nagios vt6 login:
nagios 9434 9426 4 14:31:11 ? 21:33 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
root 875 13 0 16:36:25 vt/2 0:00 /usr/sbin/ttymon -g -d /dev/vt/2 -l console -m ldterm,ttcompat -h -p nagios vt2 login:
root 19494 1603 0 10:21:49 pts/1 0:00 tail -f /opt/nagios/var/nagios.log
nagios 11813 9437 0 - ? 0:00 <defunct>
root 19529 1603 0 10:25:32 pts/1 0:00 tail -f /opt/nagios/var/nagios.log
nagios 9435 9426 5 14:31:11 ? 25:09 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11787 9445 0 - ? 0:00 <defunct>
nagios 9441 9426 5 14:31:11 ? 25:15 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11396 9427 0 - ? 0:00 <defunct>
nagios 11870 9449 0 - ? 0:00 <defunct>
nagios 11915 9448 0 - ? 0:00 <defunct>
nagios 9444 9426 4 14:31:11 ? 21:22 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9446 9426 4 14:31:11 ? 21:21 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9445 9426 4 14:31:11 ? 25:03 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9440 9426 4 14:31:11 ? 20:51 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11889 9435 0 - ? 0:00 <defunct>
nagios 11829 9450 0 - ? 0:00 <defunct>
nagios 11966 9428 0 - ? 0:00 <defunct>
nagios 11897 9438 0 - ? 0:00 <defunct>
nagios 12033 9449 0 - ? 0:00 <defunct>
nagios 9448 9426 4 14:31:11 ? 21:24 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 12074 9448 0 - ? 0:00 <defunct>
nagios 12056 9437 0 - ? 0:00 <defunct>
nagios 11715 9449 0 - ? 0:00 <defunct>
nagios 11885 9431 0 - ? 0:00 <defunct>
nagios 11356 9447 0 - ? 0:00 <defunct>
nagios 11518 9430 0 - ? 0:00 <defunct>
nagios 11956 9427 0 - ? 0:00 <defunct>
nagios 11864 9444 0 - ? 0:00 <defunct>
nagios 11493 9437 0 - ? 0:00 <defunct>
nagios 12039 9428 0 - ? 0:00 <defunct>
nagios 11521 9429 0 - ? 0:00 <defunct>
nagios 11781 9441 0 - ? 0:00 <defunct>
nagios 12020 9441 0 - ? 0:00 <defunct>
root 20132 1603 0 11:25:31 pts/1 0:00 tail -f /opt/nagios/var/nagios.debug
nagios 11416 9436 0 - ? 0:00 <defunct>
nagios 9436 9426 4 14:31:11 ? 21:11 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11503 9443 0 - ? 0:00 <defunct>
nagios 9437 9426 5 14:31:11 ? 25:20 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9443 9426 5 14:31:11 ? 25:18 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9431 9426 4 14:31:11 ? 25:20 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9429 9426 5 14:31:11 ? 25:04 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11357 9427 0 - ? 0:00 <defunct>
nagios 11311 9445 0 - ? 0:00 <defunct>
nagios 9450 9426 4 14:31:11 ? 21:19 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11625 9442 0 - ? 0:00 <defunct>
nagios 9430 9426 4 14:31:11 ? 21:23 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9449 9426 5 14:31:11 ? 25:05 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9438 9426 4 14:31:11 ? 21:43 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9433 9426 5 14:31:11 ? 25:04 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9428 9426 4 14:31:11 ? 21:31 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9427 9426 4 14:31:11 ? 21:24 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9426 1 0 14:31:11 ? 0:09 /opt/nagios/bin/nagios -d /opt/nagios/etc/nagios.cfg
nagios 11855 9441 0 - ? 0:00 <defunct>
nagios 11342 9441 0 - ? 0:00 <defunct>
nagios 11765 9429 0 - ? 0:00 <defunct>
nagios 12129 9431 0 - ? 0:00 <defunct>
nagios 11353 9448 0 - ? 0:00 <defunct>
nagios 9447 9426 5 14:31:11 ? 25:26 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 9432 9426 4 14:31:11 ? 21:54 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11343 9442 0 - ? 0:00 <defunct>
nagios 12006 9427 0 - ? 0:00 <defunct>
nagios 12018 9439 0 - ? 0:00 <defunct>
nagios 11849 9436 0 - ? 0:00 <defunct>
nagios 12176 12175 0 15:06:30 ? 0:00 /usr/sbin/ping -n -s 192.168.1.111 56 4
nagios 11408 9435 0 - ? 0:00 <defunct>
nagios 11879 9429 0 - ? 0:00 <defunct>
nagios 11996 9428 0 - ? 0:00 <defunct>
nagios 11487 9433 0 - ? 0:00 <defunct>
nagios 11694 9436 0 - ? 0:00 <defunct>
nagios 11504 9445 0 - ? 0:00 <defunct>
nagios 11443 9432 0 - ? 0:00 <defunct>
nagios 11686 9432 0 - ? 0:00 <defunct>
nagios 12077 9428 0 - ? 0:00 <defunct>
nagios 11454 9438 0 - ? 0:00 <defunct>
nagios 11852 9438 0 - ? 0:00 <defunct>
nagios 11324 9430 0 - ? 0:00 <defunct>
nagios 11419 9441 0 - ? 0:00 <defunct>
nagios 12059 9441 0 - ? 0:00 <defunct>
nagios 11702 9441 0 - ? 0:00 <defunct>
nagios 12179 12177 0 15:06:31 ? 0:00 /usr/sbin/ping -n -s 192.168.1.175 56 4
nagios 11307 9440 0 - ? 0:00 <defunct>
nagios 11935 9437 0 - ? 0:00 <defunct>
nagios 11633 9450 0 - ? 0:00 <defunct>
nagios 11895 9439 0 - ? 0:00 <defunct>
nagios 11821 9441 0 - ? 0:00 <defunct>
nagios 11365 9432 0 - ? 0:00 <defunct>
nagios 11814 9436 0 - ? 0:00 <defunct>
nagios 11587 9445 0 - ? 0:00 <defunct>
nagios 12155 9446 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.137.39 -w 200.0,80% -c 500.0,100% -p 4
nagios 12119 9427 0 - ? 0:00 <defunct>
nagios 11843 9431 0 - ? 0:00 <defunct>
nagios 11317 9449 0 - ? 0:00 <defunct>
nagios 11792 9450 0 - ? 0:00 <defunct>
nagios 11653 9434 0 - ? 0:00 <defunct>
nagios 11510 9450 0 - ? 0:00 <defunct>
nagios 12004 9432 0 - ? 0:00 <defunct>
nagios 12044 9432 0 - ? 0:00 <defunct>
nagios 11406 9431 0 - ? 0:00 <defunct>
nagios 11524 9431 0 - ? 0:00 <defunct>
nagios 11873 9448 0 - ? 0:00 <defunct>
nagios 11972 9437 0 - ? 0:00 <defunct>
nagios 11642 9447 0 - ? 0:00 <defunct>
nagios 11485 9432 0 - ? 0:00 <defunct>
nagios 11952 9449 0 - ? 0:00 <defunct>
nagios 12171 9433 0 - ? 0:00 <defunct>
nagios 11919 9447 0 - ? 0:00 <defunct>
nagios 11481 9430 0 - ? 0:00 <defunct>
nagios 12169 9432 0 15:06:30 ? 0:00 /opt/nagios/libexec/check_ping -H 172.17.0.109 -w 100.0,20% -c 500.0,60% -p 4
nagios 11403 9432 0 - ? 0:00 <defunct>
nagios 11591 9446 0 - ? 0:00 <defunct>
nagios 12170 12169 0 15:06:30 ? 0:00 /usr/sbin/ping -n -s 172.17.0.109 56 4
nagios 12051 9436 0 - ? 0:00 <defunct>
nagios 11602 9429 0 - ? 0:00 <defunct>
nagios 11808 9431 0 - ? 0:00 <defunct>
nagios 11401 9429 0 - ? 0:00 <defunct>
nagios 11491 9435 0 - ? 0:00 <defunct>
nagios 11533 9436 0 - ? 0:00 <defunct>
nagios 12053 9438 0 - ? 0:00 <defunct>
nagios 11784 9440 0 - ? 0:00 <defunct>
nagios 11463 9445 0 - ? 0:00 <defunct>
nagios 11449 9435 0 - ? 0:00 <defunct>
nagios 11758 9449 0 - ? 0:00 <defunct>
nagios 11886 9434 0 - ? 0:00 <defunct>
nagios 11701 9440 0 - ? 0:00 <defunct>
nagios 11826 9445 0 - ? 0:00 <defunct>
nagios 11392 9447 0 - ? 0:00 <defunct>
nagios 12138 12136 0 15:06:28 ? 0:00 /usr/sbin/ping -n -s 192.168.1.84 56 4
nagios 11817 9439 0 - ? 0:00 <defunct>
nagios 11943 9440 0 - ? 0:00 <defunct>
nagios 11593 9450 0 - ? 0:00 <defunct>
nagios 11811 9435 0 - ? 0:00 <defunct>
nagios 11363 9429 0 - ? 0:00 <defunct>
nagios 11640 9428 0 - ? 0:00 <defunct>
nagios 11969 9434 0 - ? 0:00 <defunct>
nagios 11733 9434 0 - ? 0:00 <defunct>
nagios 12133 9435 0 15:06:28 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.1.184 -w 200.0,80% -c 500.0,100% -p 4
nagios 12024 9443 0 - ? 0:00 <defunct>
nagios 11489 9434 0 - ? 0:00 <defunct>
nagios 12009 9431 0 - ? 0:00 <defunct>
nagios 11420 9442 0 - ? 0:00 <defunct>
nagios 11976 9439 0 - ? 0:00 <defunct>
nagios 11999 9430 0 - ? 0:00 <defunct>
nagios 11944 9443 0 - ? 0:00 <defunct>
nagios 11986 9446 0 - ? 0:00 <defunct>
nagios 11877 9428 0 - ? 0:00 <defunct>
nagios 11565 9432 0 - ? 0:00 <defunct>
nagios 12151 9444 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.137.19 -w 200.0,80% -c 500.0,100% -p 4
nagios 11991 9449 0 - ? 0:00 <defunct>
nagios 11375 9436 0 - ? 0:00 <defunct>
nagios 11372 9434 0 - ? 0:00 <defunct>
nagios 11661 9440 0 - ? 0:00 <defunct>
nagios 11597 9427 0 - ? 0:00 <defunct>
nagios 11771 9431 0 - ? 0:00 <defunct>
nagios 11626 9443 0 - ? 0:00 <defunct>
nagios 12002 9429 0 - ? 0:00 <defunct>
nagios 12134 12133 0 15:06:28 ? 0:00 /usr/sbin/ping -n -s 192.168.1.184 56 4
nagios 11384 9441 0 - ? 0:00 <defunct>
nagios 12019 9440 0 - ? 0:00 <defunct>
nagios 12159 9447 0 - ? 0:00 <defunct>
nagios 11739 9436 0 - ? 0:00 <defunct>
nagios 11892 9437 0 - ? 0:00 <defunct>
nagios 12174 12173 0 15:06:30 ? 0:00 /usr/sbin/ping -n -s 192.168.0.84 56 4
nagios 11562 9430 0 - ? 0:00 <defunct>
nagios 11713 9446 0 - ? 0:00 <defunct>
nagios 11783 9442 0 - ? 0:00 <defunct>
nagios 12065 9445 0 - ? 0:00 <defunct>
nagios 11388 9443 0 - ? 0:00 <defunct>
nagios 12089 9435 0 - ? 0:00 <defunct>
nagios 11868 9450 0 - ? 0:00 <defunct>
nagios 11456 9439 0 - ? 0:00 <defunct>
nagios 11932 9435 0 - ? 0:00 <defunct>
nagios 12149 9445 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.1.103 -w 200.0,80% -c 500.0,100% -p 4
nagios 12045 9433 0 - ? 0:00 <defunct>
nagios 12069 9450 0 - ? 0:00 <defunct>
nagios 11390 9449 0 - ? 0:00 <defunct>
nagios 11655 9435 0 - ? 0:00 <defunct>
nagios 12087 9434 0 - ? 0:00 <defunct>
nagios 11804 9432 0 - ? 0:00 <defunct>
nagios 11675 9450 0 - ? 0:00 <defunct>
nagios 11407 9434 0 - ? 0:00 <defunct>
nagios 11656 9438 0 - ? 0:00 <defunct>
nagios 11833 9427 0 - ? 0:00 <defunct>
nagios 12013 9437 0 - ? 0:00 <defunct>
nagios 11747 9442 0 - ? 0:00 <defunct>
nagios 12167 9429 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.0.54 -w 200.0,80% -c 500.0,100% -p 4
nagios 11796 9427 0 - ? 0:00 <defunct>
nagios 12156 9449 0 - ? 0:00 <defunct>
nagios 11328 9432 0 - ? 0:00 <defunct>
nagios 11888 9436 0 - ? 0:00 <defunct>
nagios 11623 9441 0 - ? 0:00 <defunct>
nagios 11658 9437 0 - ? 0:00 <defunct>
nagios 11690 9431 0 - ? 0:00 <defunct>
nagios 12083 9433 0 - ? 0:00 <defunct>
nagios 11743 9440 0 - ? 0:00 <defunct>
nagios 11564 9429 0 - ? 0:00 <defunct>
nagios 12073 9447 0 - ? 0:00 <defunct>
nagios 11424 9445 0 - ? 0:00 <defunct>
nagios 12148 9443 0 - ? 0:00 <defunct>
nagios 12131 9434 0 - ? 0:00 <defunct>
nagios 11361 9430 0 - ? 0:00 <defunct>
nagios 11472 9449 0 - ? 0:00 <defunct>
nagios 11584 9441 0 - ? 0:00 <defunct>
nagios 12177 9435 0 15:06:31 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.1.175 -w 200.0,80% -c 500.0,100% -p 4
nagios 11522 9432 0 - ? 0:00 <defunct>
nagios 11749 9445 0 - ? 0:00 <defunct>
nagios 12100 9441 0 - ? 0:00 <defunct>
nagios 11705 9443 0 - ? 0:00 <defunct>
nagios 12152 12151 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.137.19 56 4
nagios 11556 9448 0 - ? 0:00 <defunct>
nagios 12154 12153 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.137.7 56 4
nagios 11539 9439 0 - ? 0:00 <defunct>
nagios 11628 9445 0 - ? 0:00 <defunct>
nagios 11614 9436 0 - ? 0:00 <defunct>
root 21902 1603 0 14:13:59 pts/1 0:00 tail -f /opt/nagios/var/nagios.log
nagios 11824 9443 0 - ? 0:00 <defunct>
nagios 11442 9429 0 - ? 0:00 <defunct>
nagios 11908 9444 0 - ? 0:00 <defunct>
nagios 11963 9429 0 - ? 0:00 <defunct>
nagios 11860 9440 0 - ? 0:00 <defunct>
nagios 11350 9450 0 - ? 0:00 <defunct>
nagios 11830 9449 0 - ? 0:00 <defunct>
nagios 12147 12146 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.137.16 56 4
nagios 11931 9434 0 - ? 0:00 <defunct>
nagios 11554 9449 0 - ? 0:00 <defunct>
nagios 11327 9433 0 - ? 0:00 <defunct>
nagios 11738 9437 0 - ? 0:00 <defunct>
nagios 11912 9450 0 - ? 0:00 <defunct>
nagios 12104 9445 0 - ? 0:00 <defunct>
nagios 11570 9431 0 - ? 0:00 <defunct>
nagios 11917 9428 0 - ? 0:00 <defunct>
nagios 11492 9436 0 - ? 0:00 <defunct>
nagios 12035 9448 0 - ? 0:00 <defunct>
nagios 11457 9440 0 - ? 0:00 <defunct>
nagios 11559 9427 0 - ? 0:00 <defunct>
nagios 11967 9433 0 - ? 0:00 <defunct>
nagios 12061 9442 0 - ? 0:00 <defunct>
nagios 12121 9428 0 - ? 0:00 <defunct>
nagios 11835 9428 0 - ? 0:00 <defunct>
nagios 12097 9440 0 - ? 0:00 <defunct>
nagios 12153 9450 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.137.7 -w 200.0,80% -c 500.0,100% -p 4
nagios 11435 9447 0 - ? 0:00 <defunct>
nagios 11928 9431 0 - ? 0:00 <defunct>
nagios 12082 9432 0 - ? 0:00 <defunct>
nagios 11671 9446 0 - ? 0:00 <defunct>
nagios 12081 9429 0 - ? 0:00 <defunct>
nagios 12137 12135 0 15:06:28 ? 0:00 /usr/sbin/ping -n -s 10.0.1.131 56 4
nagios 11453 9437 0 - ? 0:00 <defunct>
nagios 12144 12142 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 172.17.0.126 56 4
nagios 12040 9430 0 - ? 0:00 <defunct>
nagios 11740 9438 0 - ? 0:00 <defunct>
nagios 11405 9433 0 - ? 0:00 <defunct>
nagios 11981 9438 0 - ? 0:00 <defunct>
nagios 11946 9444 0 - ? 0:00 <defunct>
nagios 11937 9438 0 - ? 0:00 <defunct>
nagios 11987 9441 0 - ? 0:00 <defunct>
nagios 11461 9441 0 - ? 0:00 <defunct>
nagios 11762 9428 0 - ? 0:00 <defunct>
nagios 11802 9429 0 - ? 0:00 <defunct>
nagios 12141 12140 0 15:06:28 ? 0:00 /usr/sbin/ping -n -s 192.168.0.47 56 4
nagios 11698 9437 0 - ? 0:00 <defunct>
nagios 11459 9442 0 - ? 0:00 <defunct>
nagios 11608 9434 0 - ? 0:00 <defunct>
nagios 11828 9444 0 - ? 0:00 <defunct>
nagios 11896 9440 0 - ? 0:00 <defunct>
root 19418 1603 0 14:41:45 pts/1 0:00 tail -f nagios.debug
nagios 12031 9450 0 - ? 0:00 <defunct>
nagios 11900 9441 0 - ? 0:00 <defunct>
nagios 12049 9435 0 - ? 0:00 <defunct>
nagios 12068 9444 0 - ? 0:00 <defunct>
nagios 12178 9436 0 15:06:31 ? 0:00 /usr/bin/perl /opt/nagios/libexec/check_snmp_apcups_my -H 10.0.1.69
nagios 11386 9445 0 - ? 0:00 <defunct>
nagios 12142 9440 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 172.17.0.126 -w 100.0,20% -c 500.0,60% -p 4
nagios 11714 9450 0 - ? 0:00 <defunct>
nagios 12091 9436 0 - ? 0:00 <defunct>
nagios 12157 9448 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.1.106 -w 200.0,80% -c 500.0,100% -p 4
nagios 11726 9430 0 - ? 0:00 <defunct>
nagios 11854 9439 0 - ? 0:00 <defunct>
nagios 11335 9437 0 - ? 0:00 <defunct>
nagios 11973 9436 0 - ? 0:00 <defunct>
nagios 11475 9447 0 - ? 0:00 <defunct>
nagios 11696 9438 0 - ? 0:00 <defunct>
nagios 11945 9445 0 - ? 0:00 <defunct>
nagios 11377 9437 0 - ? 0:00 <defunct>
nagios 12124 9429 0 - ? 0:00 <defunct>
nagios 11719 9448 0 - ? 0:00 <defunct>
nagios 11977 9442 0 - ? 0:00 <defunct>
nagios 11901 9442 0 - ? 0:00 <defunct>
nagios 12111 9450 0 - ? 0:00 <defunct>
nagios 11777 9438 0 - ? 0:00 <defunct>
nagios 11906 9445 0 - ? 0:00 <defunct>
nagios 11764 9430 0 - ? 0:00 <defunct>
nagios 12071 9449 0 - ? 0:00 <defunct>
nagios 11847 9435 0 - ? 0:00 <defunct>
nagios 11736 9435 0 - ? 0:00 <defunct>
nagios 11756 9450 0 - ? 0:00 <defunct>
nagios 11320 9447 0 - ? 0:00 <defunct>
nagios 11978 9440 0 - ? 0:00 <defunct>
nagios 11924 9433 0 - ? 0:00 <defunct>
nagios 11707 9442 0 - ? 0:00 <defunct>
nagios 11465 9443 0 - ? 0:00 <defunct>
nagios 12046 9431 0 - ? 0:00 <defunct>
nagios 11767 9432 0 - ? 0:00 <defunct>
nagios 11508 9446 0 - ? 0:00 <defunct>
nagios 11861 9443 0 - ? 0:00 <defunct>
nagios 11721 9427 0 - ? 0:00 <defunct>
nagios 11913 9449 0 - ? 0:00 <defunct>
nagios 11772 9434 0 - ? 0:00 <defunct>
nagios 11440 9430 0 - ? 0:00 <defunct>
nagios 12079 9430 0 - ? 0:00 <defunct>
nagios 12145 12143 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.212.19 56 4
nagios 11803 9430 0 - ? 0:00 <defunct>
nagios 11983 9443 0 - ? 0:00 <defunct>
nagios 11594 9449 0 - ? 0:00 <defunct>
nagios 12135 9436 0 15:06:28 ? 0:00 /opt/nagios/libexec/check_ping -H 10.0.1.131 -w 200.0,80% -c 500.0,100% -p 4
nagios 11929 9436 0 - ? 0:00 <defunct>
nagios 11332 9434 0 - ? 0:00 <defunct>
nagios 12123 9430 0 - ? 0:00 <defunct>
nagios 11806 9433 0 - ? 0:00 <defunct>
nagios 11679 9447 0 - ? 0:00 <defunct>
nagios 11437 9427 0 - ? 0:00 <defunct>
nagios 11428 9450 0 - ? 0:00 <defunct>
nagios 12143 9441 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.212.19 -w 200.0,80% -c 500.0,100% -p 4
nagios 11760 9447 0 - ? 0:00 <defunct>
nagios 11816 9438 0 - ? 0:00 <defunct>
nagios 11345 9443 0 - ? 0:00 <defunct>
nagios 9455 9426 0 14:31:17 ? 0:00 /opt/nagios/bin/nagios -d /opt/nagios/etc/nagios.cfg
nagios 11775 9436 0 - ? 0:00 <defunct>
nagios 11823 9442 0 - ? 0:00 <defunct>
nagios 11466 9444 0 - ? 0:00 <defunct>
nagios 12140 9439 0 15:06:28 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.0.47 -w 100.0,20% -c 500.0,60% -p 4
nagios 11410 9437 0 - ? 0:00 <defunct>
nagios 11866 9446 0 - ? 0:00 <defunct>
nagios 11863 9445 0 - ? 0:00 <defunct>
nagios 12139 9437 0 - ? 0:00 <defunct>
nagios 11346 9445 0 - ? 0:00 <defunct>
nagios 11872 9447 0 - ? 0:00 <defunct>
nagios 11994 9447 0 - ? 0:00 <defunct>
nagios 11495 9438 0 - ? 0:00 <defunct>
nagios 12093 9437 0 - ? 0:00 <defunct>
nagios 12014 9436 0 - ? 0:00 <defunct>
nagios 11399 9430 0 - ? 0:00 <defunct>
nagios 12101 9442 0 - ? 0:00 <defunct>
nagios 11371 9435 0 - ? 0:00 <defunct>
nagios 11681 9428 0 - ? 0:00 <defunct>
nagios 11547 9444 0 - ? 0:00 <defunct>
nagios 12166 9430 0 - ? 0:00 <defunct>
nagios 11832 9447 0 - ? 0:00 <defunct>
nagios 11308 9441 0 - ? 0:00 <defunct>
nagios 11631 9446 0 - ? 0:00 <defunct>
nagios 12106 9444 0 - ? 0:00 <defunct>
nagios 11883 9430 0 - ? 0:00 <defunct>
nagios 11551 9446 0 - ? 0:00 <defunct>
nagios 11709 9445 0 - ? 0:00 <defunct>
nagios 11809 9434 0 - ? 0:00 <defunct>
nagios 11730 9433 0 - ? 0:00 <defunct>
nagios 11989 9450 0 - ? 0:00 <defunct>
nagios 11774 9435 0 - ? 0:00 <defunct>
nagios 11381 9439 0 - ? 0:00 <defunct>
nagios 11621 9440 0 - ? 0:00 <defunct>
nagios 11962 9432 0 - ? 0:00 <defunct>
nagios 11497 9439 0 - ? 0:00 <defunct>
nagios 12115 9448 0 - ? 0:00 <defunct>
nagios 11516 9428 0 - ? 0:00 <defunct>
nagios 12175 9434 0 15:06:30 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.1.111 -w 200.0,80% -c 500.0,100% -p 4
nagios 12043 9429 0 - ? 0:00 <defunct>
nagios 11499 9440 0 - ? 0:00 <defunct>
nagios 11665 9442 0 - ? 0:00 <defunct>
nagios 11336 9438 0 - ? 0:00 <defunct>
nagios 12160 12157 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.1.106 56 4
nagios 11845 9434 0 - ? 0:00 <defunct>
nagios 11433 9448 0 - ? 0:00 <defunct>
nagios 12126 9432 0 - ? 0:00 <defunct>
nagios 11574 9437 0 - ? 0:00 <defunct>
nagios 11315 9450 0 - ? 0:00 <defunct>
nagios 11850 9437 0 - ? 0:00 <defunct>
nagios 12066 9446 0 - ? 0:00 <defunct>
nagios 11306 9438 0 - ? 0:00 <defunct>
nagios 12008 9434 0 - ? 0:00 <defunct>
nagios 11415 9440 0 - ? 0:00 <defunct>
nagios 11413 9439 0 - ? 0:00 <defunct>
nagios 11724 9428 0 - ? 0:00 <defunct>
nagios 11445 9434 0 - ? 0:00 <defunct>
nagios 12028 9444 0 - ? 0:00 <defunct>
root 12181 1603 0 15:06:31 pts/1 0:00 grep nagios
nagios 11340 9440 0 - ? 0:00 <defunct>
nagios 11699 9439 0 - ? 0:00 <defunct>
nagios 11647 9432 0 - ? 0:00 <defunct>
nagios 11926 9432 0 - ? 0:00 <defunct>
nagios 11558 9447 0 - ? 0:00 <defunct>
nagios 12034 9447 0 - ? 0:00 <defunct>
nagios 11573 9436 0 - ? 0:00 <defunct>
nagios 11511 9449 0 - ? 0:00 <defunct>
nagios 11334 9436 0 - ? 0:00 <defunct>
nagios 11693 9435 0 - ? 0:00 <defunct>
nagios 11680 9427 0 - ? 0:00 <defunct>
nagios 11887 9433 0 - ? 0:00 <defunct>
nagios 12086 9431 0 - ? 0:00 <defunct>
nagios 12026 9446 0 - ? 0:00 <defunct>
nagios 11612 9435 0 - ? 0:00 <defunct>
nagios 11837 9430 0 - ? 0:00 <defunct>
nagios 11875 9427 0 - ? 0:00 <defunct>
nagios 11801 9428 0 - ? 0:00 <defunct>
nagios 11729 9432 0 - ? 0:00 <defunct>
nagios 11552 9450 0 - ? 0:00 <defunct>
nagios 11501 9441 0 - ? 0:00 <defunct>
nagios 11600 9428 0 - ? 0:00 <defunct>
nagios 11488 9431 0 - ? 0:00 <defunct>
nagios 12058 9440 0 - ? 0:00 <defunct>
nagios 12003 9433 0 - ? 0:00 <defunct>
nagios 12109 9446 0 - ? 0:00 <defunct>
nagios 11984 9445 0 - ? 0:00 <defunct>
nagios 11616 9437 0 - ? 0:00 <defunct>
nagios 11379 9438 0 - ? 0:00 <defunct>
nagios 11619 9439 0 - ? 0:00 <defunct>
nagios 11948 9446 0 - ? 0:00 <defunct>
nagios 11545 9443 0 - ? 0:00 <defunct>
nagios 11422 9443 0 - ? 0:00 <defunct>
nagios 11389 9450 0 - ? 0:00 <defunct>
nagios 12163 12162 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.210.38 56 4
nagios 11367 9431 0 - ? 0:00 <defunct>
nagios 12150 12149 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.1.103 56 4
nagios 11789 9446 0 - ? 0:00 <defunct>
nagios 11918 9427 0 - ? 0:00 <defunct>
nagios 11358 9428 0 - ? 0:00 <defunct>
nagios 11678 9448 0 - ? 0:00 <defunct>
nagios 11514 9447 0 - ? 0:00 <defunct>
nagios 11927 9430 0 - ? 0:00 <defunct>
nagios 11673 9444 0 - ? 0:00 <defunct>
nagios 11827 9446 0 - ? 0:00 <defunct>
nagios 12164 9428 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.1.176 -w 200.0,80% -c 500.0,100% -p 4
nagios 11536 9438 0 - ? 0:00 <defunct>
nagios 11431 9449 0 - ? 0:00 <defunct>
nagios 11904 9443 0 - ? 0:00 <defunct>
nagios 11961 9430 0 - ? 0:00 <defunct>
nagios 11588 9444 0 - ? 0:00 <defunct>
nagios 11950 9450 0 - ? 0:00 <defunct>
nagios 11718 9447 0 - ? 0:00 <defunct>
nagios 11955 9447 0 - ? 0:00 <defunct>
nagios 11742 9439 0 - ? 0:00 <defunct>
nagios 11761 9427 0 - ? 0:00 <defunct>
nagios 11546 9445 0 - ? 0:00 <defunct>
nagios 12112 9449 0 - ? 0:00 <defunct>
nagios 12136 9438 0 15:06:28 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.1.84 -w 200.0,80% -c 500.0,100% -p 4
nagios 11769 9433 0 - ? 0:00 <defunct>
nagios 11942 9442 0 - ? 0:00 <defunct>
nagios 11939 9441 0 - ? 0:00 <defunct>
nagios 12094 9438 0 - ? 0:00 <defunct>
nagios 11645 9429 0 - ? 0:00 <defunct>
nagios 12063 9443 0 - ? 0:00 <defunct>
nagios 11858 9442 0 - ? 0:00 <defunct>
nagios 9442 9426 4 14:31:11 ? 21:30 /opt/nagios/bin/nagios --worker /opt/nagios/var/rw/nagios.qh
nagios 11650 9431 0 - ? 0:00 <defunct>
nagios 11727 9429 0 - ? 0:00 <defunct>
nagios 12146 9442 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.137.16 -w 200.0,80% -c 500.0,100% -p 4
nagios 12168 12167 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.0.54 56 4
nagios 11580 9440 0 - ? 0:00 <defunct>
nagios 11922 9429 0 - ? 0:00 <defunct>
nagios 11606 9432 0 - ? 0:00 <defunct>
nagios 11997 9448 0 - ? 0:00 <defunct>
nagios 11347 9444 0 - ? 0:00 <defunct>
nagios 11794 9449 0 - ? 0:00 <defunct>
nagios 12117 9447 0 - ? 0:00 <defunct>
nagios 11314 9446 0 - ? 0:00 <defunct>
nagios 12010 9435 0 - ? 0:00 <defunct>
nagios 11321 9427 0 - ? 0:00 <defunct>
nagios 11561 9428 0 - ? 0:00 <defunct>
nagios 12047 9434 0 - ? 0:00 <defunct>
nagios 11790 9444 0 - ? 0:00 <defunct>
nagios 11970 9435 0 - ? 0:00 <defunct>
nagios 11531 9435 0 - ? 0:00 <defunct>
nagios 11528 9434 0 - ? 0:00 <defunct>
nagios 11427 9446 0 - ? 0:00 <defunct>
nagios 11819 9440 0 - ? 0:00 <defunct>
nagios 12098 9439 0 - ? 0:00 <defunct>
nagios 11666 9443 0 - ? 0:00 <defunct>
nagios 11759 9448 0 - ? 0:00 <defunct>
nagios 12173 9431 0 15:06:30 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.0.84 -w 200.0,80% -c 500.0,100% -p 4
nagios 12127 9433 0 - ? 0:00 <defunct>
nagios 11750 9443 0 - ? 0:00 <defunct>
nagios 11479 9428 0 - ? 0:00 <defunct>
nagios 11473 9448 0 - ? 0:00 <defunct>
nagios 11451 9436 0 - ? 0:00 <defunct>
nagios 11595 9448 0 - ? 0:00 <defunct>
nagios 11637 9448 0 - ? 0:00 <defunct>
nagios 11957 9448 0 - ? 0:00 <defunct>
nagios 12023 9442 0 - ? 0:00 <defunct>
nagios 11583 9442 0 - ? 0:00 <defunct>
nagios 11387 9444 0 - ? 0:00 <defunct>
nagios 11799 9447 0 - ? 0:00 <defunct>
nagios 12054 9439 0 - ? 0:00 <defunct>
nagios 11968 9431 0 - ? 0:00 <defunct>
nagios 11990 9444 0 - ? 0:00 <defunct>
nagios 11572 9435 0 - ? 0:00 <defunct>
nagios 12158 12155 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.137.39 56 4
nagios 11543 9442 0 - ? 0:00 <defunct>
nagios 11754 9446 0 - ? 0:00 <defunct>
nagios 12027 9445 0 - ? 0:00 <defunct>
nagios 11476 9427 0 - ? 0:00 <defunct>
nagios 11842 9433 0 - ? 0:00 <defunct>
nagios 11309 9443 0 - ? 0:00 <defunct>
nagios 11839 9432 0 - ? 0:00 <defunct>
nagios 11644 9430 0 - ? 0:00 <defunct>
nagios 11577 9434 0 - ? 0:00 <defunct>
nagios 11745 9441 0 - ? 0:00 <defunct>
nagios 11483 9429 0 - ? 0:00 <defunct>
nagios 11934 9439 0 - ? 0:00 <defunct>
nagios 11831 9448 0 - ? 0:00 <defunct>
nagios 11310 9442 0 - ? 0:00 <defunct>
nagios 12162 9427 0 15:06:29 ? 0:00 /opt/nagios/libexec/check_ping -H 192.168.210.38 -w 200.0,80% -c 500.0,100% -p 4
nagios 11312 9444 0 - ? 0:00 <defunct>
nagios 11838 9429 0 - ? 0:00 <defunct>
nagios 12016 9438 0 - ? 0:00 <defunct>
nagios 11753 9444 0 - ? 0:00 <defunct>
nagios 11333 9435 0 - ? 0:00 <defunct>
nagios 11669 9445 0 - ? 0:00 <defunct>
nagios 11512 9448 0 - ? 0:00 <defunct>
nagios 11541 9441 0 - ? 0:00 <defunct>
nagios 11683 9429 0 - ? 0:00 <defunct>
nagios 12076 9427 0 - ? 0:00 <defunct>
nagios 11780 9439 0 - ? 0:00 <defunct>
nagios 11910 9446 0 - ? 0:00 <defunct>
nagios 11677 9449 0 - ? 0:00 <defunct>
nagios 12102 9443 0 - ? 0:00 <defunct>
nagios 12165 12164 0 15:06:29 ? 0:00 /usr/sbin/ping -n -s 192.168.1.176 56 4
nagios 11540 9440 0 - ? 0:00 <defunct>
nagios 11305 9439 0 - ? 0:00 <defunct>
nagios 11385 9442 0 - ? 0:00 <defunct>
nagios 11786 9443 0 - ? 0:00 <defunct>
nagios 11687 9433 0 - ? 0:00 <defunct>
nagios 12037 9427 0 - ? 0:00 <defunct>
nagios 11798 9448 0 - ? 0:00 <defunct>
nagios 11607 9433 0 - ? 0:00 <defunct>
nagios 11776 9437 0 - ? 0:00 <defunct>
nagios 11881 9432 0 - ? 0:00 <defunct>
nagios 11439 9428 0 - ? 0:00 <defunct>
I noticed that nagios 3.5.1 he writes the results in the directory ... /nagios/var/spool/checkresults
root@nagios:/opt/nagios/var/spool/checkresults# ls
c.SaW8i c2Say8i.ok cd8aiwj cF6aWvj.ok checkcxa4mc checkLxa4mc checkzxa4mc cK6aynj cQ6aawj.ok cT6aWnj cwTaisj.ok
c.SaW8i.ok cB6aGvj cd8aiwj.ok cf8aqwj checkCxa4mc checkMxa4mc chTai9i cK6aynj.ok cRTa4sj cT6aWnj.ok cY5aOuj
c0Saa8i cB6aGvj.ok ceTayrj cf8aqwj.ok checkDxa4mc checkNxa4mc chTai9i.ok co6aavj cRTa4sj.ok cw8aywj cY5aOuj.ok
c0Saa8i.ok cBTaysj ceTayrj.ok checkAxa4mc checkFxa4mc checkXxa4mc cJTaOsj co6aavj.ok cs6aqvj cw8aywj.ok cz6aanj
c2Say8i cBTaysj.ok cF6aWvj checkBxa4mc checkKxa4mc checkyxa4mc cJTaOsj.ok cQ6aawj cs6aqvj.ok cwTaisj cz6aanj.ok
root@nagios:/opt/nagios/var/spool/checkresults# ls -lh
total 0I found the same situation, but no solutions
https://github.com/NagiosEnterprises/na ... /issues/84
Re: nagios logs
maybe I'm wrong compile ?
./configure --prefix=/opt/nagios --with-nagios-user=nagios --with-httpd-conf=/etc/apache2/2.2/conf.d --with-gd-lib=/usr/lib --with-gd-inc=/usr/include/gd2Re: nagios logs
The developer is aware of the issue that you are seeing and hasn't found a fix for it as far as I know.
There is a guide from Oracle's site for compiling and installing Core on a Solaris 11 server. It is geared more for version 4.0.2 but you can try it and see if that helps.
http://www.oracle.com/technetwork/artic ... 79071.html
