hi! yesterday i have clean all hosts and services with ccm in our NagiosXI 5.3.1. Today we can't apply new configurations, ccm when apply config still saying "Waiting for configuration verification .. . "
If we go to Admin/System Status, we have Monitoring,Performance and Database Backend green but al other components in red. If launch restart for Monitoring Engine he show the error after 30 seconds "Your request was not processed in a timely manner. It may still execute, as the server may be temporarily busy".
We have check:
disk space
check permisions
logs files from /var/log/httpd, /usr/local/nagiosxi/var
ps & top for CPU use
mysql access and select (this mysql is remote)
i have restarted the server and the problem persists
this is our NagiosXI System Profile
Nagios XI Installation Profile
System:
Nagios XI Version : 5.3.1
mo6nap02 3.10.0-327.36.2.el7.x86_64 x86_64
CentOS Linux release 7.2.1511 (Core)
Gnome is not installed
Apache Information
PHP Version: 5.4.16
Agent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:49.0) Gecko/20100101 Firefox/49.0
Server Name: nagiosxi.it.service
Server Address: 10.162.237.174
Server Port: 80
Date/Time
PHP Timezone: Europe/Madrid
PHP Time: Tue, 25 Oct 2016 13:37:45 +0200
System Time: Tue, 25 Oct 2016 13:37:45 +0200
Nagios XI Data
License ends in: VSPQVQ
nagios (pid 15784) is running...
NPCD running (pid 14152).
ndo2db (pid 14190) is running...
CPU Load 15: 0.05
Total Hosts: 6
Total Services: 60
Function 'get_base_uri' returns: nagiosxi.it.service/nagiosxi/
Function 'get_base_url' returns: nagiosxi.it.service/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: nagiosxi.it.service/nagiosxi/includes/components/profile/profile.php
Function 'get_backend_url(internal_call=true)' returns: localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.024 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.036 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.039 ms
--- localhost ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.024/0.033/0.039/0.006 ms
Test wget To localhost
WGET From URL: http://localhost/nagiosxi/includes/components/ccm/
Running:
/usr/bin/wget http://localhost/nagiosxi/includes/components/ccm/
--2016-10-25 13:37:47-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... 127.0.0.1, ::1
Connecting to localhost (localhost)|127.0.0.1|:80... connected.
Length: unspecified [text/html]
Saving to: '/usr/local/nagiosxi/tmp/ccm_index.tmp'
0K .......... ........ 1.53M=0.01s
2016-10-25 13:37:47 (1.53 MB/s) - '/usr/local/nagiosxi/tmp/ccm_index.tmp' saved [18900]
Network Settings
1: lo: mtu 65536 qdisc noqueue state UNKNOWN
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: ens160: mtu 1500 qdisc mq state UP qlen 1000
link/ether 00:50:56:95:12:18 brd ff:ff:ff:ff:ff:ff
inet 10.162.250.15/23 brd 10.162.251.255 scope global ens160
3: ens192: mtu 1500 qdisc mq state UP qlen 1000
link/ether 00:50:56:95:08:a7 brd ff:ff:ff:ff:ff:ff
4: ens224: mtu 1500 qdisc mq state UP qlen 1000
link/ether 00:50:56:95:3c:97 brd ff:ff:ff:ff:ff:ff
inet 10.162.237.174/23 brd 10.162.237.255 scope global ens224
5: ens256: mtu 1500 qdisc mq state UP qlen 1000
link/ether 00:50:56:95:58:21 brd ff:ff:ff:ff:ff:ff
inet 172.21.250.25/22 brd 172.21.251.255 scope global ens256
default via 10.162.236.3 dev ens224 proto static metric 100
10.162.236.0/23 dev ens224 proto kernel scope link src 10.162.237.174 metric 100
10.162.250.0/23 dev ens160 proto kernel scope link src 10.162.250.15 metric 100
172.21.248.0/22 dev ens256 proto kernel scope link src 172.21.250.25 metric 100
172.22.141.0/24 via 10.162.250.3 dev ens160 proto static metric 100
we have launched reconfigure_nagios.. this is the output
[root@mo6nap02 scripts]# ./reconfigure_nagios.sh
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2016-10-25 13:40:28-- localhost/nagiosxi/includes/components/ccm/
Saving to: ‘nagiosql.login’
[ <=> ] 38,925 --.-K/s in 0.01s
2016-10-25 13:40:28 (3.40 MB/s) - ‘nagiosql.login’ saved [38925]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2016-10-25 13:40:29-- localhost/nagiosxi/includes/components/ccm/
2016-10-25 13:40:29 (3.05 MB/s) - ‘nagiosql.login’ saved [38925]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: ‘nagiosql.export.monitoring’
[ <=> ] 21,537 --.-K/s in 0.01s
2016-10-25 13:40:30 (1.70 MB/s) - ‘nagiosql.export.monitoring’ saved [21537]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 60 services.
Checked 6 hosts.
Checked 4 host groups.
Checked 3 service groups.
Checked 40 contacts.
Checked 4 contact groups.
Checked 147 commands.
Checked 44 time periods.
Checked 0 host escalations.
Checked 6 hosts
Checked 0 host dependencies
Checked 44 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
NagiosXI 5.3.1 - Waiting for configuration verification
Re: NagiosXI 5.3.1 - Waiting for configuration verification
Do any of these KB docs resolve the problem?
https://support.nagios.com/kb/article.php?id=34
https://support.nagios.com/kb/article.php?id=144
https://support.nagios.com/kb/article.php?id=532
No. No solves it.
for add +info.
yesterday with CCM we remove all hosts, services, own host templates, own services templates, hostgrups and servicegroups. And tonight something happened that caused this failure. this morning when I started creating hosts with a new nomenclature I could not apply changes and cannot restart process via nagiosxi web.
see xi component system status screenshot attached
Database Maintenance
[Last Run 14h 42m 54s Ago]
Command Subsystem
[Last Run 14h 37m 54s Ago]
Event Manager
[Last Run 14h 37m 53s Ago]
Feed Processor
Report Engine
[Last Run 14h 38m 54s Ago]
Cleaner
Nonstop Operations Manager
System Statistics
[Last Updated 14h 38m 13s Ago]
for add +info.
Command Subsystem
Event Manager
Feed Processor
Report Engine
Cleaner
System Statistics
we have solved the problem.
The problem was the user nagios passwd has expired by a hardening of policies for pam.d
with the next command we have resolved the problem:
chage -I -1 -m 0 -M 99999 -E -1 nagios
thz for all!
regards
thz for all!
regards
Thanks for sharing the solution and glad to hear this is resolved. I'll go ahead and lock this thread now.
