Performance data aggregated graphs by hostgroup?
gavinh
Post by gavinh »
Does NagiosXI have a feature for displaying aggregated perfdata by hostgroup?
Re: Performance data aggregated graphs by hostgroup?
There isn't currently. Could you describe a bit of the use case you're looking for? I can file a feature request based off of this.
gavinh
Post by gavinh »
Basically, be able to display on a single graph, all the graph data for cpu load for an entire hostgroup.
I filed a feature request for this, so that you can select by a hostgroup + service, ID #10158.
Currently, you can do something similar to this with the Graph Explorer -> Multistacked Performance Graphs - select each host, and the CPU service, and build it out that way. Then, use the blue arrow icon to add it to a dashboard.
This link might help explain more - https://support.nagios.com/kb/article.php?id=112
gavinh
Post by gavinh »
I will check it out, deploying a POC today. Too bad ya'll just support CentOS with this thing :D
ssax
Dreams In Code
Post by ssax »
RHEL and CentOS to be more specific, which distro do you guys use as your primary?
