Hi Team,
There are there few servers which are down for past few months and server is not pinging, we are getting availability report have 94% uptime. Please help us troubleshooting the above issue.
False reporting of uptime SLA report
gselvakumar
Thanks & Regards,
Gomathyshankar Selvakumar
Re: False reporting of uptime SLA report
If the server is not pinging, then the report is showing correctly. If you'd like to change the host checks to not run a ping for the host check, then simply change it to use check_dummy and set $ARG1$ to 0.
