jmb@nagios:/tmp/nagiosxi$ sudo ./fullinstall
[sudo] password for jmb:
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system that has been tasked with other purposes or
has an existing install of Nagios Core. To create such a clean install you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n]
Proceeding with installation...
Checking MySQL credentials...
Stored MySQL password validated.
Running './0-repos'...
Repos already configured - exiting.
RESULT=0
Running './1-prereqs'...
Prereqs already installed - skipping...
Note: If you want to update the RPMs installed on this system, run your package manager's update command
RESULT=0
Running './2-usersgroups'...
Users/groups already configured - skipping.
RESULT=0
Running './3-dbservers'...
Database servers already initialized - skipping.
RESULT=0
Running './4-services'...
/etc/services already updated - skipping.
RESULT=0
Running './5-sudoers'...
sudoers already configured - skipping.
RESULT=0
Running './6-firewall'...
Firewall rules already configured - skipping.
RESULT=0
Running './7-sendmail'...
Step completed OK
RESULT=0
Running './8-selinux'...
SELinux already configured - skipping.
RESULT=0
Running './9-dbbackups'...
Database backups already configured - skipping.
RESULT=0
Running './10-phplimits'...
PHP limits already configured - skipping.
RESULT=0
Running './11-sourceguardian'...
Sourceguardian already configured - skipping.
RESULT=0
Running './12-mrtg'...
MRTG already configured - skipping.
RESULT=0
Running './13-cacti'...
Step completed OK
RESULT=0
Running './14-timezone'...
PHP timezone already configured - skipping.
RESULT=0
Running './A-subcomponents'...
Subcomponents already configured - skipping.
RESULT=0
Running './B-installxi'...
Nagios XI base files already installed - skipping.
RESULT=0
Running './C-cronjobs'...
chown: cannot access ‘/var/spool/cron/apache’: No such file or directory
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './C-cronjobs'
Linux nagios 3.13.0-32-generic #57-Ubuntu SMP Tue Jul 15 03:51:08 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
