I'd like to use the agent on most of my Windows servers. The only place I see a place to enter the Agent password is with I add a single "Windows Server".
Is there a way to auto discovery all of the machines on a subnet that have the agent installed and to put the check_xi_service_nsclient checks on that host?
Thanks.
Dave
Nagios XI 9.5
Autodiscovery and the NSClient++ agent
Re: Autodiscovery and the NSClient++ agent
You could auto discover your machines, but you'd need to apply a template to them to get services like this added automatically. (or add them to a hostgroup)
See the attached document, it might help you out quite a bit. Let me know if you have any questions about it!
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
