I would like it when I click a service group to be taken to the more "modern" view.
Here is a portion of the Service Group screen:
When I click on "All Hosts with the Symantec Virus Definitions check" I am taken to the following screen:
When I click on the 25 OK link I am taken to the more "modern" view:
This is cool however it is a filtered view and not all the objects, this is what I really want to see .... on next post, limited to 3 attachments
Suggestion - Hostgroup / Service Group Summary
- Box293
- Too Basu
- Box293
- Too Basu
Re: Suggestion - Hostgroup / Service Group Summary
This is cool however it is a filtered view and not all the objects, this is what I really want to see:
I like this view because I can see the status information for each object.
Somehow the current view seems old and doesn't have the same feel as the rest of the interface.
This is a result of using the "Unified" views for the hostgroup and servicegroup dashlets. This setting can be changed in the Admin->Performance Settings page. The "out of place" stylesheet is actually the Nagios Core interface being called. The "unified" view from Nagios Core doesn't use AJAX, so there are performance benefits from using the unified view, but the look is different from the rest of XI.
- Box293
- Too Basu
Yes I remember I enabled the use unified servicegroup screens as the performance impact was noticable. Not much I can do here then.
Cheers
Cheers
