Dear Support,
I've got "No performance graphs were found for this service. If you have just started monitoring this object then it may take up to 15 minutes for the performance graphs to appear." message instead of performance graphs.
I did notfind any difference between services where this graph exists or does not.
I've checked https://support.nagios.com/kb/article.php?id=9 but it was not relevant for me.
LOG_LEVEL = 2 in our config but i last entry is from year 2014 in /usr/local/nagios/var/perfdata.log
Could you please help me where should i find the difference or the reason for this problem.
Regards,
Zoltan
Performance graphs
avandemore
Re: Performance graphs
XI > Admin > System Profile > Download Profile
Please include the zip file in your response. You can PM myself or other support personnel if you have privacy concerns.
Previous Nagios employee
avandemore
I have received your profile. What is the output of:
# service npcd statusPrevious Nagios employee
patalenszki.zoltan
Sorry for delayed answer!
npcd (pid 2220) is running...
Can you share the output of the following commands executed from the CLI of your Nagios XI machine:
ps aux | grep php
cat /usr/local/nagios/etc/nagios.cfg
cat /usr/local/nagios/etc/commands.cfg | grep perfdata
ls /usr/local/nagios/var/spool/perfdata/ | wc -l
ls /usr/local/nagios/var/spool/xidpe/ | wc -l
patalenszki.zoltan
Please find here:
: ps aux | grep php : cat /usr/local/nagios/etc/nagios.cfg : cat /usr/local/nagios/etc/commands.cfg | grep perfdata
0
0
Zoltan
0
0
Zoltan
Can you share the outputs of these commands:
I would also run this and watch it for a few minutes. See if the number increases/decreases or remains at 0.
service npcd restart
ls -al /usr/local/nagios/var/spool/
su nagios
/usr/bin/perl /usr/local/nagios/libexec/process_perfdata.pl
/usr/bin/perl /usr/local/nagios/libexec/process_perfdata.pl -d HOSTPERFDATA
exitCode: Select all
watch 'ls /usr/local/nagios/var/spool/perfdata/ | wc -l'Former Nagios employee
