Stuck at the start
Stuck at the start
I just stood up a virtual machine with centos 7. I installed Nagios core on it and everything completed successfully, but I am unable to access to the web portal. Please assist. I know we have allowed port 80 already.
avandemore
Re: Stuck at the start
Please run the following and show the output:
# yum install -y -q net-tools
# netstat -plnt
# iptables -LPrevious Nagios employee
Attached is the error file.
error.txt- (5.2 KiB) Downloaded 485 times
Here is the output:
[root@localhost ~]# yum install -y -q net-tools
Package net-tools-2.0-0.17.20131004git.el7.x86_64 already installed and latest version
[root@localhost ~]# netstat -plnt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 967/sshd
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 1682/master
tcp6 0 0 :::80 :::* LISTEN 10624/httpd
tcp6 0 0 :::22 :::* LISTEN 967/sshd
tcp6 0 0 ::1:25 :::* LISTEN 1682/master
[root@localhost ~]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
INPUT_direct all -- anywhere anywhere
INPUT_ZONES_SOURCE all -- anywhere anywhere
INPUT_ZONES all -- anywhere anywhere
DROP all -- anywhere anywhere ctstate INVALID
REJECT all -- anywhere anywhere reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
FORWARD_direct all -- anywhere anywhere
FORWARD_IN_ZONES_SOURCE all -- anywhere anywhere
FORWARD_IN_ZONES all -- anywhere anywhere
FORWARD_OUT_ZONES_SOURCE all -- anywhere anywhere
FORWARD_OUT_ZONES all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
OUTPUT_direct all -- anywhere anywhere
Chain FORWARD_IN_ZONES (1 references)
FWDI_public all -- anywhere anywhere [goto]
Chain FORWARD_IN_ZONES_SOURCE (1 references)
Chain FORWARD_OUT_ZONES (1 references)
FWDO_public all -- anywhere anywhere [goto]
Chain FORWARD_OUT_ZONES_SOURCE (1 references)
Chain FORWARD_direct (1 references)
Chain FWDI_public (2 references)
FWDI_public_log all -- anywhere anywhere
FWDI_public_deny all -- anywhere anywhere
FWDI_public_allow all -- anywhere anywhere
ACCEPT icmp -- anywhere anywhere
Chain FWDI_public_allow (1 references)
Chain FWDI_public_deny (1 references)
Chain FWDI_public_log (1 references)
Chain FWDO_public (2 references)
FWDO_public_log all -- anywhere anywhere
FWDO_public_deny all -- anywhere anywhere
FWDO_public_allow all -- anywhere anywhere
Chain FWDO_public_allow (1 references)
Chain FWDO_public_deny (1 references)
Chain FWDO_public_log (1 references)
Chain INPUT_ZONES (1 references)
IN_public all -- anywhere anywhere [goto]
Chain INPUT_ZONES_SOURCE (1 references)
Chain INPUT_direct (1 references)
Chain IN_public (2 references)
IN_public_log all -- anywhere anywhere
IN_public_deny all -- anywhere anywhere
IN_public_allow all -- anywhere anywhere
Chain IN_public_allow (1 references)
ACCEPT tcp -- anywhere anywhere tcp dpt:ssh ctstate NEW
Chain IN_public_deny (1 references)
Chain IN_public_log (1 references)
Chain OUTPUT_direct (1 references)
avandemore
I don't see port 80 allowed. Can you try with your firewall disabled?
So I was able to disable the firewall on the Nagios server and I am still unable to access the site.
It is working now. I had to completely stop the firewall instead of disabling it on the nagios server.
Was there anything further we can help with or are we okay to close the thread?
There is one more thing....I am now getting the following after I added a windows host.
Please post the output of these commands:
Try to restart the nagios service:
Then if it fails, send us the output of this command:
Thank you
chage -l nagios
sestatus
grep nag /etc/group
grep "User \|Group " /etc/httpd/conf.d/nagios
service nagios status
ps aux |grep nagios.cfgCode: Select all
service nagios restartCode: Select all
tail -n100 /var/log/messages /usr/local/nagios/var/nagios.log
