Nagios XI 5.4.4 (NRPE Monitoring Wizard) problem
chands
Post by chands »
Hello there.
I have setup Nagios XI 5.4.4 on RHEL 7.2. The server is fully up and running
Problem: NRPE Monitoring Wizard hangs and keeps spinning in the X! web GUI "Waiting for configuration verification......"
1. NRPE is setup correctly on the AIX client
2. I can run manual checks via command line from the nagios server to the client
Problem is I cannot add NRPE clients via the XI GUI.
Also I have setup the nagios server to use HTTPS could this be a problem
Any help would be much appreciated
Re: Nagios XI 5.4.4 (NRPE Monitoring Wizard) problem
If the verification fails after the server was configured for SSL, one if the changes were missed and that usually causes the issue you are having.
Make sure the following settings were done on the server.
Edit the file /usr/local/nagiosxi/html/config.inc.php and find the following line:
$cfg['use_https']=false;
Change it to:
$cfg['use_https']=true;
and this change as well
From the Nagios XI GUI navigate to the Configure > Core Config Manager > CCM Admin > Settings menu
Change Server Protocol to https at the bottom of the menu and click the Save button to update the settings.
If you are still having the waiting for verification issue,
Can you login to the XI server as root and run this command,
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
Then run the wizard and post back the output of the tail command so we can view any errors.
chands
Post by chands »
Hello there
Hey thanks for the response.
That has fixed my problems
Thanks very much for a quick response
Cheers
Post by mcapra »
Did you have additional questions regarding this issue, or can we close this thread?
chands
Post by chands »
Hello
No more question regarding this problem, it can be closed off
Cheers
