Upgrade nagios 3.5.1 to 4.3.2
Where is the nagios configuration file?
I have upgraded from 3.5.1 to 4.3.2 and nagios uses nagios3 configuration files that are located in a different directory than /usr/local/nagios/
The apache directory is /usr/local/nagios/share/, but nagios uses old configuration files in another directory
Where to change the location to the nagios configuration file?
Re: Upgrade nagios 3.5.1 to 4.3.2
Where Nagios Core looks for configuration objects depends on the main nagios.cfg file. Mine is found here and contains the following directives to point to some configuration objects:
So if all my configuration files were located somewhere else, I would need to change all my cfg_file and cfg_dir values. Or create symlinks. Probably best to just update the main nagios.cfg file.
Unless i'm misunderstanding what you're looking for. If I am, could you please clarify?
[root@nagios ~]# cat /usr/local/nagios/etc/nagios.cfg | grep cfg_
cfg_file=/usr/local/nagios/etc/objects/commands.cfg
cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/objects/templates.cfg
cfg_file=/usr/local/nagios/etc/objects/hostgroups.cfg
#cfg_file=/usr/local/nagios/etc/objects/windows.cfg
#cfg_file=/usr/local/nagios/etc/objects/switch.cfg
#cfg_file=/usr/local/nagios/etc/objects/printer.cfg
# extension) in a particular directory by using the cfg_dir
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
#cfg_dir=/usr/local/nagios/etc/switches
#cfg_dir=/usr/local/nagios/etc/routers
# object configuration files (see the cfg_file and cfg_dir options above).Unless i'm misunderstanding what you're looking for. If I am, could you please clarify?
I installed nagios from repositories
The configuration of the hosts is in the directory /etc/nagios3/
Then I upgraded nagios to version 4.3.2 and the configuration files of this version 4.3.2 are in the /usr/local/nagios/
but nagios continues to use the old configuration (/etc/nagios3/ not /usr/local/nagios/)
Do you understand my question?
And as I go to the nagios page I have a message:
unable to get process status [\b] (attachment)
Is this also the error associated with the above?
- nagios.JPG (14.76 KiB) Viewed 3980 times
I found a solution https://support.nagios.com/forum/viewto ... =7&t=30236, but I have debian not centos
Just to confirm but is the Nagios system running for you now?
If you don't have anymore questions, shall I close and lock the post for you?
But the problem was not solved
Nobody has an idea? So why would you want to close the post?
How did you upgrade nagios to version 4.3.2? What document/guide/tutorial did you follow?
Run the following command:
then post the nagios.txt file on the forum, that was created by the above command in you current working directory.
Also, run:
and show the output.
locate nagios > nagios.txtAlso, run:
ps -ef | grep [n]agiosBe sure to check out our Knowledgebase for helpful articles and solutions!
https://assets.nagios.com/downloads/nag ... ading.htmllmiltchev wrote:How did you upgrade nagios to version 4.3.2? What document/guide/tutorial did you follow?
in attachmentlmiltchev wrote:Code: Select all
lmiltchev wrote:and show the output.Code: Select all
nagios 587 1 0 maj31 ? 00:00:00 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
nagios 874 1 0 maj31 ? 01:11:14 /usr/sbin/nagios3 -d /etc/nagios3/nagios.cfg- Attachments
nagios.txt- (221.99 KiB) Downloaded 359 times
