System Info
Linux Distribution and version?
*Linux version 2.6.18-274.3.1.el5 ([email protected]) (gcc version 4.1.2 20080704 (Red Hat 4.1.2-51)) #1 SMP Tue Sep 6 20:14:03 EDT 2011
CentOS release 5.7 (Final)
32 or 64bit?
32 bit
VMware Image or Manual Install of XI?
VMware Image
Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL?
No.
ISSUE:
When we go to the nagiosxi URL, we get the following: (please see attached)
It comes up with the installer.php instead.
Please help.
Thank you
Nagios Installer at Login
Re: Nagios Installer at Login
This should only come up the first time you go there and completes the installation and allows you to set the admin password and email.
After you set the fields to the values you like, and click install on the bottom, future visits to http://<IP_ADDRESS>/nagiosxi should take you to the login prompt.
