How to configure services with a $
anoopjeev
Post by anoopjeev »
I am having trouble configuring check command for sql serivce. It has $ sign in it.
something like these:
define serivce{
use generic -service
host_name host23
service_description sql server
check_command check_nt!SERVICESTATE! -d SHOWALL -l MSSQL$SQLEXP
it gives errors.please suggest.
Re: How to configure services with a $
Post by mcapra »
Some documentation with various solutions:
https://support.nagios.com/kb/article/n ... mmand.html
https://support.nagios.com/kb/article/n ... cters.html
I realize it says Nagios XI in the title, but much of the same solutions also apply to Nagios Core.
Post by dwhitfield »
Thanks @mcapra!
OP, let us know if that does not resolve your issue. Also, please give the exact error if you continue to have problems, as well as the updated config.
anoopjeev
Post by anoopjeev »
Thank you mcapra for sharing the links. Adding a backslash \ and two dollars worked for most of the services except for the below.
please check the attachment for the error in nagios console and also the service to be monitored:
use         generic-service
host_name                IA0CW005
service_description         SQL ServerRTCLOCAL
check_command   check_nt !SERVICEST! -d SHOWALL -l MSSQL\$$RTCLOCAL
error in console
error in console
your command somehow got chopped and should be SERVICESTATE not SERVICEST
this
use         generic-service
host_name                IA0CW005
should be this
host_name IA0CW005
check_command check_nt !SERVICESTATE! -d SHOWALL -l MSSQL\$$RTCLOCAL
anoopjeev
Post by anoopjeev »
i feel stupid for not checking the command twice. thank you.
Thank you mcapra for sharing the links and scott for pointing my mistake.
This topic can be closed now.
