Waiting for verification configuration.... hangs
ghowe18
Post by ghowe18 »
New to Nagios XI.
Brand new install of Nagios XI 5.4.8 in the web UI I am going through the configuration wizard using the NCPA and the UI is able to connect to the host I want to monitor but when I click finish it hangs on the "Waiting for verification configuration......." step.
I don't get a timeout or failure notification. Any help is greatly appreciated.
kyang
Re: Waiting for verification configuration.... hangs
Post by kyang »
Hi @ghowe18,
Could you run this command and post the output?
I'd like to see if there's a config error.
Post by dwhitfield »
Thanks @kyang!
Also, please take a look at https://support.nagios.com/kb/article.php?id=34
