i am not able to open topic in customer forum (but we have purchased the license, we have the customer id).
We encounter a problem after nagios upgrade from 5.2.9 to 5.4.9.
Once we modify any service inside the config manager we receive an "apply configuration" error:
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/myservername.cfg', starting on line 88)
This is the original configuration:
# Service configuration file
# Created by: Nagios Core Config Manager 2.5.2
# Date: 2017-09-06 18:10:29
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
host_name myservername
service_description CPU Usage
use TMP_srv_gen_noH24
check_command check_xi_service_nsclient!!CPULOAD!-l 5,90,95!!!!!
_xiwizard windowsserver_sacmi
register 1
after the apply the service cfg result like this, but in the gui the hostname is correctly associated:
# Created by: Nagios Core Config Manager 2.6.8
# Date: 2017-10-02 17:18:20
register 1
If we modify host/hostgroup and so.. we do not encounter any error in applyng the config.
Support Talea
