Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =6&t=45870
In the future, please create a new thread and link to the old one instead of adding on.
Hi all,
after "Delete --> Write --> Verify --> Apply configuration" we recieved the same error
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/SSISVR15.cfg', starting on line 96)
But in the graphical user interface the host is associated
We come back to an archive snapshot and nagios work again
When we try to modify any services or create newone we recieve the error above.
We also try to
disassociate the host from the services --> save --> associated the host again ... but when we press on apply configuration, "core config manager" generate the file .cfg of of the services without the line "host_name"
Andrea
Missing host_name in service.cfg after update - andrea
andrea.errani
kyang
Re: Missing host_name in service.cfg after update - andrea
@andrea.errani,
Have you tried repeating the process of Delete --> Write ---> Verify?
You may have different objects with multiple config errors.
Or is it the same error message for "SSISVR15.cfg"
Did you also do an upgrade? If, so what version did you upgrade to and what version of XI are you on?
