I was wondering if it was possible to generate a report that only includes host availability. We use Nagios XI, and I see in the existing "Availability" report that the report includes both host and service availability. We would like to send out a report that excludes service availability and only shows host availability for a specified host group.
Is this possible at all in XI?
David
Generating a report for only host availability
david.j.skinner
kyang
Re: Generating a report for only host availability
Hey @david.j.skinner, Welcome to the forums!
I believe you can click advanced, and click the checkbox for "Do not show service data"
That will limit your availability reports to only host or host groups.
Is that what you wanted?
david.j.skinner
I checked but I don't see that as a checkbox option under "Advanced".
Is it possible that is included in a newer version of Nagios XI from what we run now? We currently are on version 5.2.0.
David
David
kyang
Most likely, If there isn't an advanced option then it was added in a more recent version of XI.
Do you have any intentions of upgrading to our latest version? Are you a customer? There are a vast amount of fixes from 5.2.0 to 5.4.10, which is where we are now. With a new upcoming release soon.
david.j.skinner
We are intending to do that soon but will definitely speed that up knowing this!
Thank you for your help!
David
David
kyang
No problem! Do you have any more questions or are we okay to close this thread?
