NRDP not processing Host and Service checks
karthek
Post by karthek »
I have NRDP configured with Nagios core. Passive host and service checks are not getting processed by NRDP. I don't see them in nagios.cmd nor in nagios.log, no errors while submitting from http://localhost/nrdp
But, the downtime requests are getting processed and i'm seeing them in the nagios.cmd file. What could be missing?
"Machines don't make mistakes, we do."
Re: NRDP not processing Host and Service checks
Post by dwhitfield »
What version of NRDP are you running? 1.5.1 was released today: https://github.com/NagiosEnterprises/nr ... HANGES.rst
karthek
Post by karthek »
I was using 1.5.0
kyang
Post by kyang »
Did you upgrade to 1.5.1?
Otherwise, what is the result when you submit a check in http://localhost/nrdp?
Does it process with something like this?
<result>
<status>0</status>
<message>OK</message>
<meta>
<output>2 checks processed.</output>
</meta>
</result>
Or a different error?
karthek
Post by karthek »
That's the thing here. No errors. Just a OK at the bottom and that too disappears soon,
karthek
Post by karthek »
i've upgraded it to 1.5.1
If i submit the command, it's not showing any output, just a blank page. Any thoughts?
What are your permissions on the nagios.log and status.dat? Please attach your nagios.cfg.
karthek
Post by karthek »
Please see below file permissions and attached nagios.cfg
root@karthek:/usr/local/nagios/var# ll nagios.log
-rw-r--r-- 1 nagios nagios 8171 Jan 2 23:22 nagios.log
root@karthek:/usr/local/nagios/var# ll status.dat
-rw-rw-r-- 1 nagios nagios 13471 Jan 2 23:22 status.dat
nagios.cfg
(43.78 KiB) Downloaded 543 times
kyang
Post by kyang »
It looks like there was a fix/pull that was mentioned on the NRDP Github.
https://github.com/NagiosEnterprises/nrdp/pull/30
You could use the pull request, or just don't use the default JSON format which is fine too.
Trying sending a check with something like this against, on a host/service you have for passive checks.
    "checkresults": [
            "checkresult": {
                "type": "host",
                "checktype": "1"
            "hostname": "localhost",
            "state": "0",
            "output": "Everything looks okay! | perfdata=1;"
            "checkresult": {
                "type": "service",
                "checktype": "1"
            "servicename": "SSH",
            "state": "1",
            "output": "WARNING: Danger Will Robinson! | perfdata=1;"
Once you submit it with this format, try a tail and see if it worked.
tail -10 /usr/local/nagios/var/nagios.log
Here's my example.
[1515014710] PASSIVE SERVICE CHECK: localhost;SSH;1;WARNING: Danger Will Robinson!
[1515014710] SERVICE ALERT: localhost;SSH;WARNING;SOFT;1;WARNING: Danger Will Robinson!
[1515014710] PASSIVE HOST CHECK: localhost;0;Everything looks okay! Test!
Let us know!
karthek
Post by karthek »
Sorry, i was away.
Got it working by installing the latest NRDP.
Thank you for support. You may lock this thread.
