Restoring Nagios XI to factory default did not work well
habuhejleh
Dear All,
Kindly note that I did restore to the factory default to our Nagios XI by the below command:
cd /usr/local/nagiosxi/scripts/
./restore_defaults.sh
However the home page still displaying the hosts and services.
I tried redoing the above commands but still the same
I tried also rebooting the server but no luck
Please advise on how to solve this problem
Thank you,
Haitham
Thank you,
Haitham
kyang
Re: Restoring Nagios XI to factory default did not work well
When you run the restore_defaults script. What is the output?
Is it similar to what is in this kb article? Could you post it for us.
https://support.nagios.com/kb/article.php?id=164
Also, what version of Nagios XI and what OS are you on?
./restore_defaults.shAlso, what version of Nagios XI and what OS are you on?
habuhejleh
Dear Kyang,
Please find he output below:
]0;root@localhost:/usr/local/nagiosxi/scripts[root@localhost scripts]# ./restore_defaults.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2018-02-15 09:56:13-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: “nagiosql.login”
[<=> ] 0 --.-K/s
[ <=> ] 35,825 --.-K/s in 0.02s
2018-02-15 09:56:14 (1.88 MB/s) - “nagiosql.login” saved [35825]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2018-02-15 09:56:14-- http://localhost/nagiosxi/includes/components/ccm/
[<=> ] 0 --.-K/s
2018-02-15 09:56:14 (2.11 MB/s) - “nagiosql.login” saved [35825]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: “nagiosql.export.monitoring”
[<=> ] 0 --.-K/s
[ <=> ] 21,689 --.-K/s in 0.01s
2018-02-15 09:56:15 (1.65 MB/s) - “nagiosql.export.monitoring” saved [21689]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/localhost.cfg', starting on line 65)
RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
tar: Removing leading `/' from member names
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1518611043.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1518611043.tar.gz
RESETTING PERMS
Tha Nagios XI version is 5.3.0
Linux used is
[root@localhost nagiosadmin]# uname -mrs
Linux 2.6.32-642.4.2.el6.x86_64 x86_64
[root@localhost nagiosadmin]# uname -a
Linux localhost.localdomain 2.6.32-642.4.2.el6.x86_64 #1 SMP Tue Aug 23 19:58:13 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost nagiosadmin]# cat /etc/*release
CentOS release 6.8 (Final)
PLease advise ASAP
CMDLINE
[<=> ] 0 --.-K/s
LOGIN SUCCESSFUL!
Array
RESETTING PERMS
CMDLINE
[<=> ] 0 --.-K/s
LOGIN SUCCESSFUL!
CMDLINE:
[<=> ] 0 --.-K/s
OUTPUT:
Nagios Core 4.1.1
License: GPL
RET: 1
RESETTING PERMS
Linux used is
PLease advise ASAP
kyang
The error is in this file
On line 65. That a look there and see what is missing.
Could you PM or post your profile for us to review?
Nagios XI Profile --> On the XI Home Page click "Admin" > "System Profile" --> "Download Profile" button
Save the profile.zip file and upload it here or PM me.
If you receive a PROFILE BUILD FAILED
Please follow this article,
https://support.nagios.com/kb/article.p ... ategory=44
After you PM the profile please update this thread, unless you post the profile on here. Thanks
/usr/local/nagios/etc/services/localhost.cfgOn line 65. That a look there and see what is missing.
habuhejleh
Hi Kyang,
Here is the output of cat -n localhost.cfg
64 define service {
65 host_name localhost
66 service_description Service Status - httpd
67 use local-service
68 check_command check_xi_service_status!httpd!!!!!!
69 register 1
70 }
I have uploaded the the profile. please advise asap.
64 define service {
69 register 1
70 }
Please try the steps mentioned in this KB article:
https://support.nagios.com/kb/article.php?id=144
Something funky is going on with your configs. Probably in the CCM rather than the actual files.
I'd also double check, in the Core Config Manager, the service definitions you have for localhost. Make sure that that the services you have defined in the Core Config Manager are tied to a host.
kyang
Thanks for the help @mcapra!
habuhejleh, please double check your definitions in the Core Config Manager as mcapra has suggested.
Don't forget to run through the kb article for those instructions.
Click Write --> Delete --> Write --> Verify --> Post the output of "Verify"
If no errors, then proceed to the restore_defaults.sh script.
./restore_defaults.shYou do not have the required permissions to view the files attached to this post.
habuhejleh
Hi ,
Please find below the output:
64 define service {
69 register 1
70 }
And find in the attached a screen show of localhost services.Please advice ASAP.
64 define service {
69 register 1
70 }
kyang
Did you run through the steps in that kb article? Here is the link.
Could you send a screenshot of this service in your Core Config Manager? (CCM)
Here is an example of what I would like to see.
Thanks!
Thanks!
habuhejleh
Yes I went through those steps with no luck
please find screen shots as below:
Please advise. Note that this Nagios is installed on VM.
