Issue sending alerts to contacts
Nagios XI Issue
We have an interesting issue where when we create a new user and assigning it either through a Contact Group or directly on a host through the Alerts Settings Tab. The user does not get alerted during a failure. We have tried re-writing config files, upgraded to the latest version, recreating the user. Any help would be appreciated.
Re: Issue sending alerts to contacts
Are you first creating the user through Admin -> Users?
Has the user logged in to the UI and setup their Notification preferences to turn on notifications and selected the types they want to receive?
That's how I created the user yet when I masquerade as the new user and attempt to change the monitoring I receive the following.
Notification Preferences
Management of notification preferences is not available because your account is not configured to be a monitoring contact. Contact your Nagios XI administrator for details
He definitely has an enabled contact under CCM Alerting Contacts
In the CCM -> Contacts does the Contact Name match his username exactly?mbowden wrote:He definitely has an enabled contact under CCM Alerting Contacts
If you edit the contact and click the "Alert Settings" Tab
What is listed under
Manage Host Notification Commands &
Manage Service Notification Commands ??
also, had the user logged in besides your masquerading? I ask because they aren't fully setup until they login with a username/password and accept the TOS
I just deleted the user and recreated the user, Admin -> Add new User -> Create as Monitoring Contact selected,
if I go to CCM --> Contact --> select contact Alert Settings, nothing is assigned under "Manage Host Notification Commands" or Manage Service....
It it already exists I don't believe it would be modified, you want
xi_host_notification_handler &
xi_service_notification_handler
respectively
Also on Common Setting Tab you should have xi_contact_generic template applied
and then Save and apply configuration
respectively
Those settings are in place and he still is not receiving alerts,
define contact {
contact_name bbises
alias Brett Bises
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period bbises_notification_times
service_notification_period bbises_notification_times
host_notification_options d,u,r,f,s,
service_notification_options w,u,c,r,f,s,
host_notification_commands xi_host_notification_handler,xi_service_notification_handler
service_notification_commands xi_host_notification_handler,xi_service_notification_handler
email [email protected]
use xi_contact_generic
define contactgroup {
contactgroup_name Ecosystem Alert Group
alias Ecosystem Alert Group
members bbises }
define host {
host_name s-degwks-a.bowdoin.edu
use basic_linux_server_host_template
alias s-degwks-a.bowdoin.edu
display_name s-degwks-a.bowdoin.edu
address s-degwks-a.bowdoin.edu
hostgroups Basic Linux Hosts
check_command check-host-alive!!!!!!!!
contact_groups Ecosystem Alert Group
_xiwizard linux-server
register 1
define contact {
contact_name bbises
alias Brett Bises
members bbises }
define host {
register 1
This
should be
also, can you confirm that the user has logged in and accepted the TOS?
service_notification_commands xi_host_notification_handler,xi_service_notification_handlerCode: Select all
service_notification_commands xi_service_notification_handlerRe: Issue sending alerts to contacts
I logged in using his username/password and accepted the EULA
Still no go,
define contact {
contact_name bbises
alias Brett Bises
host_notification_period bbisesti_notification_times
service_notification_period bbisesti_notification_times
Still no go,
define contact {
contact_name bbises
alias Brett Bises
After doing this do you still get thismbowden wrote:I logged in using his username/password and accepted the EULA
Still no go,
mbowden wrote:Notification Preferences
