Hi all,
could you help me with following issue:
1) I try to connect to Active Directory: Admin -> Manage Users -> Add Users from LDAP/AD
2) I choose AD server defined under LDAP/AD Integration -> Authentication Server
3) username: xmpanagios, pass: ****, Next
-> issue: Unable to authenticate: 80090308: LdapErr: DSID-0C09042F, comment: AcceptSecurityContext error, data 52e, v2580
4) If I use LDAP (I choose LDAP server defined under LDAP/AD Integration -> Authentication Server),
username: CN=xmpanagios,OU=usr,OU=MPSV,DC=AD,DC=MPSV,DC=CZ
pass: ****, it works fine
Thanks for help
Ivo
Active Directory - Unable to authenticate
Re: Active Directory - Unable to authenticate
52e indicates bad credentials. Assuming those are correct, it is probably a bad setting in the AD configuration. Can you provide a screenshot of Admin > Users > LDAP/AD Integration > *edit the ad config* ? Feel free to PM it to me if you cannot post it publicly.
It works now. I have incorrect account suffix.
I apologize for vasting of your time.
Regards
Ivo
Regards
Ivo
No worries
Always glad to resolve something quickly!
