Currently we have NagiosXi installed on RHEL 7.3, we have master-master replication working on the databases, Do we need to make any files to be in sync with each other on both masters?
Nagios XI Replication
Re: Nagios XI Replication
The files and folders found in https://assets.nagios.com/downloads/nag ... ios-XI.pdf. Additionally the snmp(tt) config at /etc/snmp/.
MOHANREDDY
So, all these files should in sync with each other on both the servers? By what frequency they should be in sync?
MOHANREDDY
Should the files mentioned in this doc should be in sync on both master as a part of Replication?cdienger wrote:The files and folders found in https://assets.nagios.com/downloads/nag ... ios-XI.pdf. Additionally the snmp(tt) config at /etc/snmp/.
If you're planning to have some fail-over scenario, then yes, the files should be synced. Which ones and how often depends on what exactly you'd like to keep synced and how often there may be changes to them in your environment.
