We are trying to monitor the Data Domain tool from Nagios XI, for that i searched the in Nagios exchange and only found the below
Check Data Domain plugin:
http://exchange.nagios.org/directory/Pl ... in/details
I tried installing the plugin and tested the plugin from the Nagios XI server, initially it gave an error "./check_dd.pl: /usr/local/groundwork/bin/perl: bad interpreter: No such file or directory"
I found that perl was installed in other location so executed the script using the actual perl location, now I'm getting another error attached.
Nagios XI: Data Domain monitoring
Re: Nagios XI: Data Domain monitoring
This plugin doesn't come standard with Nagios XI, but based on the result you are getting I would guess that either the SNMP community string public isn't correct, or the server you are reaching out to doesn't know what that OID is.
