Nagios XI 5.4.8 manual upgrade error
rjjimenez
Post by rjjimenez »
good morning
We are trying to update to version 5.5.1 from version 5.4.8 and when manually running the upgrade of nagios the following error appears:
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.4.1'
/etc/init.d/nagios: line 87:   499 Segmentation fault      $NagiosBin -vp $NagiosCfgFile > "$TMPFILE"
I attach the log file of the upgrade.
Best Regards
Re: Nagios XI 5.4.8 manual upgrade error
Can you verify that the nagios user can write to /tmp/
Also, can you run the following to make sure that you have a valid configuration before upgrade
rjjimenez
Post by rjjimenez »
Hi Good morning.
I'm running the upgrade script with the root user and write correctly in the /tmp
I attach the result image of the command:
If you run the following do you get an error?
/etc/init.d/nagios start
rjjimenez
Post by rjjimenez »
Hi.
The result of the command is correct, it does not show any error
Can we run the upgrade again and see if we get the same error?
rjjimenez
Post by rjjimenez »
Hello.
We have re-runed the manual update but again give the same error. We attached the log of the upgrade:
nagiosxi-upgrade-20181001.log
After the update we check the status of the nagios and get the following:
Can you open a ticket at https://support.nagios.com/tickets/
We may need to walk through this with you via remote to get everything working correctly
