NRPE agent installation on different OS
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
I have to install nrpe agent on a number of servers. I checked in Nagios Support Knowledgebase for the document, but I am getting confused as there are a number of OS versions.
Can you please provide me standard documents for nrpe agent installation on below OS versions:
Ubuntu 10.04LTS
Ubuntu 11.04
CentOS 6.4
RHEL 5.10
Ubuntu 12.04.4 LTS
RHEL 6.4
RHEL 7
Ubuntu 16.0.4 LTS
Ubuntu 14.04.5
CentOS 7
Thanks in advance!!
Thanks & Regards,
I2MP Team.
Re: NRPE agent installation on different OS
Instead of compiling NRPE on various OS version, then installing nagios plugins, you could just use our official Linux NRPE agent installer:
https://assets.nagios.com/downloads/nag ... _Agent.pdf
It will work on most of the operating systems you listed. It will install both, NRPE and the Nagios plugins. It won't work on Ubuntu 10.04, 11.04, and RHEL 5.10 though, which reached end of life some time ago... For these systems, you will have to find some other way of installing NRPE or upgrade them.
awilson
Post by awilson »
I hope that this isn't considered hijacking. Is the preferred way to install on AIX to compile nrpe?
RIDS_I2MP
Post by RIDS_I2MP »
Thanks for the update.
I will refer the below link as suggested and get back to you if I get any issues.
Please do not close this topic :)
Thanks & Regards,
I2MP Team.
No problem - we will keep the topic open.
