Custom Endpoint is not found.
Nagios XI is installed on a VM running Red Hat Enterprise Linux Server release 7.2 (Maipo).
This VM is 64bit.
Installation is Manual.
No Gnome, No proxy, No SSL.
Created a custom api endpoint following instructions on page Custom API Endpoint in folder /usr/local/nagiosxi/html/includes/components/xxx.
when I invoke this endpoint using curl, i get an error
No Endpoint: <name of endpoint>
Custom API Endpoint on RHEL 7.2 is not active
vikas.karandikar
Re: Custom API Endpoint on RHEL 7.2 is not active
Can you share the code you created? Also, can you confirm the directory structure where component is placed in
is your custom endpoint in the file named xxx.inc.php ?
vikas.karandikar
Please close this ticket. File was secured incorrectly.
