NagiosXI 5.5.3 don't save changes (timeout)
morabanc
Post by morabanc »
Hi guys,
I'm installing nagios xi in a new centos machine.
After all goes fine, i create a host and a service and when i try "apply configuration" and a loop become and never finish
Waiting for configuration verification.......................................................................[..]
Trying to check config manually:
#/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
Error: There are no services defined!
        Checked 0 services.
        Checked 1 hosts.
        Checked 1 host groups.
        Checked 0 service groups.
        Checked 2 contacts.
        Checked 2 contact groups.
        Checked 127 commands.
        Checked 8 time periods.
        Checked 0 host escalations.
        Checked 1 hosts
        Checked 0 host dependencies
        Checked 8 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   1
***> One or more problems was encountered while running the pre-flight check...
     directives and data definitions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
I think that there are something with permision file or mariaDB db because i also get this kind of error when i try to save a mediawiki file.
Doing other checks i found on internet:
# tail /usr/local/nagiosxi/var/cmdsubsys.log
PROCESSED 0 COMMANDS
I tried to modify sudoers file, php.ini ... but i leaved it as i get before.
Can you help me please.
benjaminsmith
Re: NagiosXI 5.5.3 don't save changes (timeout)
Post by benjaminsmith »
Let's trying running the reconfiguration script.
Please run the following command as root:
./reconfigure_nagios.sh
To reset the permissions, run from the scripts folder:
./reset_config_perms.sh
Let us know if this is resolves the issue.
Knowledgebase articles for troublehsooting configuration issues:
https://support.nagios.com/kb/article.php?id=34
https://support.nagios.com/kb/article.php?id=144
morabanc
Post by morabanc »
Hi benjaminsmith,
I execute both scripts and my changes (new host and new service) was applied, but when i try to configure a new one and click "apply configuration" i get the same error, a loop ...
Results are:
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
  No files to import
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
  Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.2
License: GPL
Checking objects...
        Checked 13 services.
        Checked 2 hosts.
        Checked 2 contacts.
        Checked 2 hosts
Total Warnings: 0
Total Errors:   0
> Return Code: 0
Actually the only way to apply changes is:
1- Create a new host/service
2- Execute (reconfigure_nagios.sh)
But after this when i try to force an immediate check i can't (your request was not processed in a timely manner. it may still execute, as the server may be temporarily busy).
Another thing i checked is that when i "re-schedule" through nagios core works fine but in nagiosxi not.
Thanks a lot
morabanc
Post by morabanc »
After reboot it seems to be ok now, but Mediawiki still without working.
Any idea ?
Many thanks
morabanc wrote:Hi,
Any idea ?
Many thanks
Unfortunately we cannot assist with Mediawiki, I would suggest contacting their support.
morabanc
Post by morabanc »
Ok thanks for all guys !
benjaminsmith
Sounds good. I will go ahead and lock this thread.
Thanks for the update.
