Hi
I have Nagios XI Version 2014R1.2.
When I ran Apply Configuration it takes along time and the page get stuck.
I did restart to all the services and repaier the DB but it did helped.
Any idea why?
Apply Configuration takes too long
Re: Apply Configuration takes too long
The version of XI you are running is from a little over 4 years ago, is there a possibility of upgrading because the Apply configuration process has been significantly improved since then.
Hi scottwilkerson,
I can't update due to maintenance experation a few years ago.
There is any other solution?
Unfortunately I don't have any specific recommendations other than possible adding more resources to the server. You can contact [email protected] to work out a renewal.elade wrote:Hi scottwilkerson,
