Top 10 hosts list consuming more CPU's
zahidhh
Post by zahidhh »
Hello All,
I want to create a dashboard which can show top 10 hosts which is consuming more CPU's , Memory in Nagios XI
Nagios XI configuration details
OS :- RHEL 7.4
Arch :- x86-64
Manual Configuration
Please help
cdienger
Re: Top 10 hosts list consuming more CPU's
Post by cdienger »
XI will not produce reports like this, but you could use Home > Graphs > Graph Exploer > Mutistacked Performacne Graph, to display cpu and memory usage for multiple hosts on the same graph.
zahidhh
Post by zahidhh »
Hi Cdienger,
Thanks for you reply, i have created this Mutistacked Performance Graph but when our hosts count is more in hundred's in one hosts group, then this graph presentation is not enough to understand the clear picture hosts-wise.
we are Nagios XI customer, and i want to tech help from Nagios tech support , where and how i can create support ticket and how i can contact Nagios customer support, any direct number please ?
Regard's
jforcier
Post by jforcier »
To create a ticket you can log into the Support Center using your Support Forum username and password.
https://support.nagios.com/tickets/
If your forum account has not been added to your account as a support contact, you can add it with the Add Support Contact form.
https://support.nagios.com/add-contact/
