NagiosXI Fusion install error...
This support forum board is for questions relating to Nagios Fusion.
vishfx
Post by vishfx »
Hi Nagios Team,
Am installing Nagios fusion using the below method on Red Hat Enterprise Linux Server release 7.3 (Maipo) :
wget https://assets.nagios.com/downloads/nagiosfusion/fusion-latest.tar.gz
tar xzf fusion-latest.tar.gz
cd nagiosfusion
./fullinstall
It throws me the below error in install.log :
Nagios Fusion Installation Log
DATE: Mon Nov  5 03:16:50 CST 2018
DISTRO INFO:
OracleServer
7.3
x86_64
Nagios Fusion Installer
This script will do a complete install of Nagios Fusion by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS, RHEL, Ubuntu or Debian. To create such a clean install you should have
selected ONLY the 'Base' package in the OS installer.
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
THIS IS A NEW INSTALL!
Is there a way to install Nagios Fusion from https://repo.nagios.com/?repo=rpm-rhel ???
Kindly assist.
Regards,
Vish.
Re: NagiosXI Fusion install error...
We do not have Fusion available as an RPM install, however what you are seeing isn't an error, it is just the beginning of the install output.
vishfx
Post by vishfx »
here is the bash console output.
install script fails with multiple errors as below:
usermod: user 'apache' does not exist.
ERROR: MySQL not installed - exiting.
RESULT=1
Regards,
Vish.
however, in the install log we see:
DISTRO INFO:
OracleServer
7.3
x86_64
Oracle Linux is NOT a supported OS. You would need to install Fusion on RHEL or CentOS.
Platform Support
As of the time of writing, Nagios Enterprises is only able to officially provide support for installing Nagios Fusion on the following Linux Distributions:
• RHEL 6.x 32-bit and 64-bit, RHEL 7.x
• CentOS 6.x 32-bit and 64-bit, CentOS 7.x
https://assets.nagios.com/downloads/nag ... ctions.pdf
vishfx
Post by vishfx »
The OEL 7.x we use is 100% compatible with RHEL 7.x
Can we tweak the install script to install on OEL 7.x ?
Will this setup be supported by you folks ?
Regards,
Vish.
You are welcome to try. It is possible that Fusion will install and work on Oracle.
Not officially, no. We will always try to help if we can, but we cannot guarantee that Fusion would work as intended if it is installed on a non-supported OS.
vishfx
Post by vishfx »
Hi ,
I managed to install fusion.
however, getting the below error with nagiosadmin login:
I even tried reset using below command, but still getting same error.
/usr/local/nagiosfusion/scripts/reset_nagiosadmin_password.sh --password=admin
Regards,
Vish.
Have you tried recovering your password by clicking on the "Forgot your password?" link?
vishfx
Post by vishfx »
Hi ,
Dell will cover OS level support for OEL 7.x
And we have been running many a apps and never faced any compatibility issue due to compatibility with RHEL 7.x
Can you provide support for only the Nagios Fusion part ?
Also,
Am getting the below error while retrieving password :
NOTE: email has the default values ( root@localhost or nagios@localhost )
Regards,
Vish.
Are you trying to log in with the nagiosadmin's password that you created on the "initial setup" or the password that you created for the AD/LDAP user?
Can you run the following command from the command line and show the output?
echo 'select * from users;' | mysql -t -uroot -pfusion fusion
