I'm having an installation problem with Nagios XI VMware version.
This is what I have done so far:
1) I have downloaded the
VMWare EXSi
ESXi 5.0 Installable (CD ISO)/
08/24/11 | 5.0.0 | 291 MB | Binary (.iso) /
and successfully installed it on an Intel i3 PC.
2) Then I have downloaded the
NagiosXI VMware Virtual Machine
http://assets.nagios.com/downloads/nagi ... vmware.zip
612 MB
*2011R2.1*
February 13, 2012
3) And finally I downloaded and installed
VMware vCenter Converter Standalone
https://www.vmware.com/tryvmware/?p=converter/
But when I try to convert the virtual machine and define the ESXi PC
as the destination, a "generic system fault error" appears.
I believe, a similar case has been introduced here:
http://communities.vmware.com/thread/279197
Has anyone else experienced problems with the conversion and do you have any ideas for fixing this problem?
Thanks in Advance,
Mark
Error in VMWare conversion
Re: Error in VMWare conversion
I've seen this issue before. It seems like vmware standalone converter 4.3 worked fine fine but 5.0 fails with a "generic system fault error". Not sure how to fix it but some people claim that they fixed the issue by opening port 902 to ESX hosts. See this article:
http://kb.vmware.com/selfservice/micros ... Id=1012382
Thank you for the reply.
I will try this and inform here how it went.
