I was wondering if it would be possible to make a feature request to add an option to the graph explorer to be able to select a custom time range from date x to 'now'. The max timerange seems to be last 365 days, but I would like add a graph to a dashboard of the last 2 years or longer.
Grtz
Willem
Graph explorer custom time range from xx to now
Nagios XI 5.8.1
https://outsideit.net
Re: Graph explorer custom time range from xx to now
The custom time period is meant to be for inputting custom time periods unless I'm misunderstanding what you're looking for?
Are you just saying that you want a easier way to populate the To input box with the current date/time? Like a Now button or something?
Sean,
What we would like is to be able to create 'last 2/3/4 year' multistacked graphs. When a custom timeperiod is choosen, the graphs doesnt update when time passes. A 'now' button would be cool, but it has to stay 'now' when adding it to a dashboard.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
That makes sense, thank you for clarifying, I've requested that the feature be added:
Am I okay to lock the topic?
FR: XI - Graph Explorer Multi-Stacked Graphs (and others) - Add an option for a rolling timeperiod (like 2 years ago until now) so that the dashlets follow the time as it passes instead of a static start/end timeRe: Graph explorer custom time range from xx to now
Please lock
Nagios XI 5.8.1
