Disable Ping checks on Host
mindspring
Post by mindspring »
Hi There,
I have a few hosts where ICMP and ping is not allowed so the checks on the host always shows down, yet the services are up.
Is there any way to disable the host ping check or tell it that the host is up, even though pings are blocked?
See example attached
Thanks.
Re: Disable Ping checks on Host
You can always change the ping command to something else, that makes sense in your environment - checking a port that is open, check_dummy, etc. Please review our documentation on changing the host alive check here:
https://assets.nagios.com/downloads/nag ... _In_XI.pdf
mindspring
Many thanks, this worked like a charm!
mindspring wrote:Many thanks, this worked like a charm!
Great! Locking
