Nagiox xi upgrade failed
Trying to upgrade from 5.4.10 to 5.5.17 and it failed because it is trying to connect to redhat license server whichh never did before.
bolson
Re: Nagiox xi upgrade failed
Hello Jimeaton,
The error would suggest that you are unable to access a RHEL repository because the system is not registered with Red Hat. Please got to Admin >> System Profile under System Config >> download profile and attach the generated profile.zip
Also, from /tmp or whichever folder you're running the upgrade from and locate the file upgrade.log and attach this foile as well.
Thank you for visiting the Nagios Support Forum.
