snmp walk works but snmp get doesnt
benhank
Post by benhank »
Ok so I have run the snmp walk wizard:
And it worked just fine.
however...
[root@lkennagiost01 ~]# /usr/local/nagios/libexec/check_snmp -H 172.22.191.190 -C I$ilonpublic -P 2c -o enterprises.12124.2.52.1.5.1
SNMP problem - No data received from host
[update]
I have verified that the receiving server is correct configured to receive snmp queries, my network guys have assured me that there are no issues with our firewalls, I have iptables disabled on my test box, which is polling other devices via snmp.
I just dont get why xi can do a snmpwalk and get the data I need, but the checks that I create with the wizards fail, and running the check from the command line fails.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: snmp walk works but snmp get doesnt
Try increasing the timeout for the check_snmp plugin by adding -t 59 to the command and see if that works.
Another thing to try is to put single quotes around the community string as it has a $ in it.
 /usr/local/nagios/libexec/check_snmp -H 172.22.191.190 -C 'I$ilonpublic' -P 2c -o enterprises.12124.2.52.1.5.1
The wizard is escaping and that is why it is working there.
benhank
Post by benhank »
THANKS MAN!
Proudly running:
Nagios Fusion
benhank
Post by benhank »
you can lock it up WHO00ooooOOOOOO!
Proudly running:
Nagios Fusion
