I need some help. I installed NagEventLog and everything seems ok. (connection seems successful)
I'm interested only to monitor System EventLog. Now I can see only one Event but I would like to see in Nagios XI all System Events Log. When I tried to click on the place (to expand the view) I received "Active checks are disabled for this service" message. Is it possible what I want ? And so ... how?
Many thanks !
Cheers
Bogdan
chagrinboy2001
Cheers,
bb
bb
Re: Active checks are disabled for this service
This is correct, because it is a passive check, meaning Nagios doesn't decide when a check result will happen, NagEventLog does.
I believe the setting you are looking for is in the Event Log Agent on the client computer. there you can set which logs should be sent.
