My nagios server (process_ suddenly stopped running.
When i run service nagios status i get
No lock file found in /var/run/nagios.lock
and at the web interface
unable to get process status
or
nagios (pid 2469) is running...
and at the web interface not running
At both nagios does not actually run
lock File - nagios not running
npolovenko
- Support Tech
Re: lock File - nagios not running
Hello, @orani. Does the lock file reappear after you start the nagios process?
service nagios start
No. When i run service nagios start there are no erros but no lock file is created and nagios dont really start
npolovenko
- Support Tech
@orani, When did this issue start and what changes were done to the server prior to this?
What's the output of:
Can you show me the output of:service nagios status
Also, please show me the output of the following commands:tail -200 /usr/local/nagios/var/nagios.log
cat /etc/rc.d/init.d/nagios | grep NagiosRunFile=
cat /usr/local/nagios/etc/nagios.cfg | grep lock
please close this thread. It was a critical issue and we restored our backup so i cannot reply and give more infos about the problem.
Lockingorani wrote:please close this thread. It was a critical issue and we restored our backup so i cannot reply and give more infos about the problem.
