I have nagios running under groundwork, and as we have not looked at the install in a while, the disk is now full.
Where should I delete the log files from ?
Can you tell me
a) what log file format will be (i.e. the file name, and contents) - so I can check I am deleting the correct files
b) Where these files will be located under nagios.
Many thanks
Mark
Help clearing log files
wormfishin
Re: Help clearing log files
I haven't used groundwork myself, but this page looks helpful.
http://proddoc.groundworkopensource.com ... tation.htm
