Monitoring Engine won't start after upgrade
sathevaner
Post by sathevaner »
I just upgraded to the latest version of Nagios, manually on the command line, and the monitoring engine refuses to start. The web UI upgrade procedure was left in a hung "Update in progress. Please wait. Update may take a few minutes," Upon reporting that it is running 5.6.3, it is still stuck in that state.
Please advise on next steps for troubleshooting.
benjaminsmith
Re: Monitoring Engine won't start after upgrade
Post by benjaminsmith »
Hi @sathevaner,
There's a known issue with the web upgrade stalling on occasion. Please follow the guide to reset the upgrade status.
Nagios XI - Reset Upgrade Status In Web Interface
Then restart Nagios:
systemctl restart nagios
Let me know if the Monitoring Engine status is green again.
sathevaner
Hello, @benjaminsmith,
Thank you for the manual reset instructions for the database backend. This did not resolve the Monitoring Engine issue, as it is still refusing to start. I am unclear on why it will not do so after the manual upgrade.
benjaminsmith
Is the server showing Nagios 5.6.3 in the lower left side of the screen? Let's try stopping everything and then re-start the whole Nagios stack. Please run the following from the terminal:
systemctl stop crond
systemctl stop npcd
systemctl stop nagios
systemctl stop ndo2db
pkill -9 -u nagios
rm -rf /usr/local/nagiosxi/var/dbmaint.lock
rm -rf /usr/local/nagiosxi/var/event_handler.lock
rm -rf /usr/local/nagiosxi/scripts/reconfigure_nagios.lock
systemctl restart mysqld || systemctl restart mariadb
systemctl start ndo2db
systemctl start nagios
systemctl start npcd
systemctl start crond
systemctl restart httpd
If it does not come back up, can you PM your system profile so we can take a closer look at the logs. Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket.
sathevaner
Restarting all the relevant services did not result in the Monitoring Engine starting. Attached is the System Profile.
ssax
Dreams In Code
Post by ssax »
This is why, it's because your configuration is invalid:
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'Check status of APC battery' on host 'APC-UPS-ITEC-043'
Error: Could not register service (config file '/usr/local/nagios/etc/services/APC-UPS.cfg', starting on line 16)
You can validate with:
Please go to Configure > Core Config Manager > Services:
- Edit that service and make sure all these are set:
Invalid max_attempts, check_interval, retry_interval, notification_interval
- Save
Then go to Configure > Core Config Manager > Tools > Config File Management:
- Click the Delete Files button (don't worry, it's safe, they will be rewritten)
- Then click the Write Configs button
- Then click the Verify Files button, if it verifies properly, try to start the nagios service from the CLI.
- If it doesn't verify, keep fixing the errors it shows until it does.
ssax
Dreams In Code
Post by ssax »
Additionally (see previous post): When an apply configuration fails, it reverts the files on the filesystem to the last known-good state so that your monitoring continues to work, so... to get them into a bad state so I can review exactly what the issues is, you need to do the steps below exactly without any steps in between:
Please go to Configure > Core Config Manager > Tools > Config File Management:
- When they are done being written, run this command before doing anything else (don't apply config or anything):
zip -r /tmp/NAGIOSBADFILES.zip /usr/local/nagios/etc
Then attach the resulting /tmp/NAGIOSBADFILES.zip file to the ticket so that I can review it.
sathevaner
Thank you, I was unaware that this was a legit host in our list. I have corrected the issue. This thread may now be closed.
benjaminsmith
Thanks for the update and glad you got this worked out.
