Receiving the following error, when trying to add a new server for monitoring.
"Backend login to the Core Config Manager failed'
Thank you!
MNcomputer
benjaminsmith
Re: Backend login to the Core Config Manager failed
Hello @MNcomputer,
This problem is often the result of Nagios XI not being able to resolve "localhost". Open up a terminal on the server and run the following commands and post the full output to this thread:
Thanks.
See: Nagios XI - Apply Configuration Fails - Backend login to the Core Configuration failed
su nagios
./reconfigure_nagios.sh
