NSCP-0.5.0.62-x64 not starting after server 2016 reboot
lpereira
Post by lpereira »
Hello:
I'm installing NSClient on several Windows Servers 2016. and i'm having problems after server is rebooted, the service nsclient does not start automatically. even if the option "automatic" is selected. i must login and start the service by hand.
Is there any fix for this?
Thanks in advance.
Re: NSCP-0.5.0.62-x64 not starting after server 2016 reboot
How did you install the agent? Did you use the zip file, MSI installer, silent install? Is NSClient++ service running as a "Local System account" on this server or as your account (user)?
lpereira
Post by lpereira »
lmiltchev wrote:How did you install the agent? Did you use the zip file, MSI installer, silent install? Is NSClient++ service running as a "Local System account" on this server or as your account (user)?
Yes, is the same procedure i do for all the servers. Also i have selected "restart" the service on the recovery tab. However every time the server back online after a reboot, the serive does not start automatically
See the Screenshots for reference.
This only happen on 2016 servers, 2008 & 2012 works fine
I suggest installing the latest 0.5.2 stable version of the NSClient++ agent which can be downloaded as this link.
https://nsclient.org/download/0.5.2/
See if that fixes the issue.
