For background, I'm working with an APC PDU to send out traps based on the settings on the device. The idea is to send notifications where a phase of power draws more than X amps, or the PDU draws more than Y kilowatts. It's also capable of banks of outlets as well as individual outlets that could also be in an overload condition.
I had originally thought that there would be separate traps for several different types of alarms, but they're all being sent with more generic trap definitions. From the Powernet428 MIB these are the trap names:
rpduInformationalCondition
rpduInformationalConditionCleared
rpduWarningCondition
rpduWarningConditionCleared
rpduCriticalCondition
rpduCriticalConditionCleared
Here is one of the definitions, they are all effectively the same except for the SEVERITY passed and the OID of the trap:
rpduInformationalCondition TRAP-TYPE
ENTERPRISE apc
VARIABLES { mtrapargsString02, mtrapargsString03, mtrapargsInteger, mtrapargsInteger02, mtrapargsInteger03, mtrapargsString }
DESCRIPTION
"INFORMATIONAL: A RPDU informational condition has been detected.
The first variable is the serial number.
The second variable is the device name.
The third variable is the error number.
The fourth variable is the device number.
The fifth variable is the instance number.
The sixth variable is the trap text message."
--#TYPE "RPDU: Informational condition detected."
--#SUMMARY "An informational condition has been detected."
--#SEVERITY INFORMATIONAL
--#TIMEINDEX 1
--#HELP ""
--#HELPTAG 0
--#STATE OPERATIONAL
::= 754Code: Select all
Fri Aug 16 10:11:04 2019 .1.3.6.1.4.1.318.0.752 WARNING "Status Events" IP_ADDRESS - Received trap "rpduWarningCondition" with variables "enterprises.318.2.3.10.0:SERIAL_NUMBER enterprises.318.2.3.11.0:PDU_NAME enterprises.318.2.3.1.0:873595137 enterprises.318.2.3.6.0:1 enterprises.318.2.3.7.0:1 enterprises.318.2.3.3.0:Rack PDU 1: Device near overload."
Fri Aug 16 10:11:19 2019 .1.3.6.1.4.1.318.0.752 WARNING "Status Events" IP_ADDRESS - Received trap "rpduWarningCondition" with variables "enterprises.318.2.3.10.0:SERIAL_NUMBER enterprises.318.2.3.11.0:PDU_NAME enterprises.318.2.3.1.0:874381569 enterprises.318.2.3.6.0:1 enterprises.318.2.3.7.0:1 enterprises.318.2.3.3.0:Rack PDU 1: Bank near overload on bank #1."
Fri Aug 16 10:11:36 2019 .1.3.6.1.4.1.318.0.752 WARNING "Status Events" IP_ADDRESS - Received trap "rpduWarningCondition" with variables "enterprises.318.2.3.10.0:SERIAL_NUMBER enterprises.318.2.3.11.0:PDU_NAME enterprises.318.2.3.1.0:873988353 enterprises.318.2.3.6.0:1 enterprises.318.2.3.7.0:1 enterprises.318.2.3.3.0:Rack PDU 1: Phase near overload on phase #1."
Fri Aug 16 10:11:38 2019 .1.3.6.1.4.1.318.0.752 WARNING "Status Events" IP_ADDRESS - Received trap "rpduWarningCondition" with variables "enterprises.318.2.3.10.0:SERIAL_NUMBER enterprises.318.2.3.11.0:PDU_NAME enterprises.318.2.3.1.0:873988354 enterprises.318.2.3.6.0:1 enterprises.318.2.3.7.0:2 enterprises.318.2.3.3.0:Rack PDU 1: Phase near overload on phase #2."
