This XML file does not appear to have any style information associated with it. The document tree is shown below.
<result>
<script/>
<script/>
<status>-1</status>
<message>HTTPS REQUIRED</message>
</result>
Fixed it, thanks for the pointer. Just change true to false to disable https until the issue is fixed.
It sounds good! I will be closing this topic now as there is nothing else we can do at the moment. The issue has been reported already. I expect our developers to be fixing it soon. Thank you!
