Yesterday, I followed the upgrade instructions as seen here: http://assets.nagios.com/downloads/nagi ... ctions.pdf
However, I'm still showing that our system is running 1.9, not 2.1.
Is there an additional step that I'm missing that isn't listed in the instructions?
Updated install, but it didn't update..(1.9->2.1)
Re: Updated install, but it didn't update..(1.9->2.1)
Can you try clearing the /tmp directory of any of the following files:
Then try downloading the tarball once more and running the upgrade.
/tmp/nagiosxi
/tmp/xi-*.tar.gzRe: Updated install, but it didn't update..(1.9->2.1)
is there a log file that I could check to see if something hung up the first time?
the log file should be in /tmp/nagiosxi/install.log
One thing to note, if all went well, to complete the upgrade you usually need to log out of the web interface and log back in,
