Add a URL link to the status information
Is it possible to add a URL link to the status information column。
I try to write a simple perl script~
printf(" \<a href=test.html\>Click here to see test \</a\>")
but nagios shows like this is I want~
Status information
Anybody knows how to slove it
Steven
Status information
Steven
Re: Add a URL link to the status information
This is not available in Nagios Core, but is an option in Nagios XI
You might be able to get a similar effect with notes for a particular host/service:
https://support.nagios.com/forum/viewto ... 72#p252672
I also get into modifying the source code to add custom elements to the status.cgi page:
https://support.nagios.com/forum/viewto ... 87#p222987
Thanks @mcapramcapra wrote:You might be able to get a similar effect with notes for a particular host/service:
Thank for your replies.
I did see someone using the hyperlink in the status information field of the nagios core V3.5. Just, I don't know how he does it. The result of my test, nagios does not Interpret the HTML , or What plug-in do I need to install?
Oh, you can edit the cgi.cfg
change this
to this
change this
escape_html_tags=1Code: Select all
escape_html_tags=0Re: Add a URL link to the status information
scottwilkerson wrote:Oh, you can edit the cgi.cfg
change thisto thisCode: Select all
escape_html_tags=0
Thank you very much
I'll try later
Sounds good!stevenhmy wrote:scottwilkerson wrote:Oh, you can edit the cgi.cfg
escape_html_tags=0
Thank you very much
I'll try later
scottwilkerson wrote:Sounds good!stevenhmy wrote:scottwilkerson wrote:Oh, you can edit the cgi.cfg
escape_html_tags=0
Thank you very much
I'll try later
It's working
thanks again
Great!stevenhmy wrote:It's working
thanks again
Locking
