how can i reduce the frequency of the email from nagios related to Nagios Deadpool Report.
I am getting 100 email per day related to the Nagios deadpool report. I would require 1 per day.
deadpool report email frequency
benjaminsmith
Re: deadpool report email frequency
Hello @IT-OPS-SYS
Email notifications are sent based on the following criteria.
Reference
How to Use Deadpool in Nagios XI
Currently, there isn't the option to create a daily summary email. You can could increase the Stage 1 and Stage 2 time requirements to make it more difficult for host or services to get add to the deadpool or deleted/deactivated.Email notifications will be sent when the host or service has been added to the deadpool or when they have been deactivated/deleted from the Nagios XI config.
Reference
IT-OPS-SYS
i got that logic of getting the alert but in my case i am getting the email for the same content without any further service/host being added to the pool.
after every 1 minute I am getting the same email with the same list of services/hosts that are being added to the deadpool. how can we reduce the duplicity in the email content.
benjaminsmith
Hello @IT-OPS-SYS,
So what is happening here there is a configuration dependency preventing the same list of services/hosts from being deactivated and Nagios XI is restoring the previous configuration snapshot and the process starts all over again.
You'll need to look at the list of services/hosts and perform a manual deactivation, and this should take care of the duplicate messages. Hosts and Services can be deactivated in the CCM by going to Configure > CCM > Monitoring > Host or Service and then search for the host or service, click on it and uncheck the Active option from Common Settings.
