Check Freshness running early
hbouma
Post by hbouma »
I have several Nagios XI 5.6.1 servers running on RHEL 7 64bit VM's. We have several passive checks, all setup with a freshness value of 7200 and the check command is "check_dummy" with ARG1 as 0 "Resetting check after 2 hours".
Here are some examples from our nagios.log file (Service and HOST name redacted) As you can see, Services 1 and 4 were reset more often than the 2 hour freshness check. The passive process is a custom log scraping we wrote and does not include the ability to send the resets themselves.
[1569277851] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569278149] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569278448] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569278747] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569279045] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569279344] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569279642] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569279941] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569280240] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569281134] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569281433] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569281732] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569282030] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569282329] SERVICE ALERT: HOST1;SERVICE_1;OK;HARD;1;OK: Resetting check after 2 hours
[1569284459] SERVICE ALERT: HOST1;SERVICE_2;OK;HARD;1;OK: Resetting check after 2 hours
[1569286497] SERVICE ALERT: HOST1;SERVICE_3;OK;HARD;1;OK: Resetting check after 2 hours
[1569287213] SERVICE ALERT: HOST1;SERVICE_4;OK;HARD;1;OK: Resetting check after 2 hours
[1569289004] SERVICE ALERT: HOST1;SERVICE_4;OK;HARD;1;OK: Resetting check after 2 hours
[1569291693] SERVICE ALERT: HOST1;SERVICE_4;OK;HARD;1;OK: Resetting check after 2 hours
[1569293185] SERVICE ALERT: HOST1;SERVICE_4;OK;HARD;1;OK: Resetting check after 2 hours
[1569308553] SERVICE ALERT: HOST1;SERVICE_5;OK;HARD;1;OK: Resetting check after 2 hours
[1569323646] SERVICE ALERT: HOST1;SERVICE_4;OK;HARD;1;OK: Resetting check after 2 hours
[1569324123] SERVICE ALERT: HOST1;SERVICE_3;OK;HARD;1;OK: Resetting check after 2 hours
Here is the config for Service 4 (Host and Service name redacted)
Any assistance figuring out why we are resetting the check so often would be appreciated.
Re: Check Freshness running early
According to our documentation, under the "Check Settings" tab, you need to disable active checks, and enable passive checks for the service.
From your screenshot, it is not really clear if the service is configured properly, as you selected the "Skip" option... and we haven't seen the template that is being in use.
Can you verify that your active checks are disabled and passive checks enabled for your service? Also, make sure that your PHP and system time are not out of sync:
Admin > System Config > System Profile > View System Info > Date/Time
and that you don't have multiple nagios processes running on your server:
ps -ef | grep nagios.cfg | grep -v grep
hbouma
Post by hbouma »
The service was created using the passive check wizard in XI. Here is the configuraiton out of the config file:
    host_name               XXXXXXXXXXXXXXXXXX
    service_description      XXXXXXXXXXXXXXXXXX
    use                      xiwizard_passive_service
    servicegroups            XXXXXXXXXXXXXXXX
    check_command            check_dummy!0 "Resetting check after 2 hours"!!!!!!!
    max_check_attempts       1
    check_period             xi_timeperiod_24x7
    check_freshness          1
    freshness_threshold      7200
    event_handler            XXXXXXXXXXXXXXXXXXXXXXX
    notification_interval    120
    notification_period      xi_timeperiod_24x7
    notifications_enabled    1
    contact_groups           XXXXXXXXXXXXXXXXXXXXXXXXX
    _xiwizard                passivecheck
    register                 1
I have checked the date and time:
PHP Time: Tue, 24 Sep 2019 15:39:06 -0400
System Time: Tue, 24 Sep 2019 15:39:06 -0400
It does appear that 2 copies of Nagios are running. When I run a systemctl restart nagios, it always starts a second copy. I have killed the pids and then ran the start, it is always running 2 copies. This appears to be the case for all 9 of my Nagios XI servers:
$ ps -ef | grep nagios.cfg | grep -v grep
nagios   29289     1  0 09:22 ?        00:00:12 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   29313 29289  0 09:22 ?        00:00:01 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Active checks do show enabled, that, but they have no timeframe for when to run:
hbouma
Post by hbouma »
The odd thing is that it doesn't always reset after the same number of minutes. Here is the service history for one of the checks.
Actually, this is normal... you don't have multiple nagios processes running. One is a child process - look at the PID:
Having said that, it would be easier to troubleshoot the issue if we had some more information. Can you PM me (or any other member of the Nagios Support team) your latest profile (Admin > System Profile > Download Profile), the name of the service in question, and the host it is attached to? Thank you!
hbouma
Post by hbouma »
Please provide the command line to build the profile. I get the following from the GUI:
PROFILE BUILD FAILED
Array
CODE: 1
hbouma
Post by hbouma »
PM Sent.
Replied via PM.
hbouma
Post by hbouma »
In case anyone else runs into the same issue, we found the problem and fix.
As part of our Maintenance procedure, we had been using the Nagios external commands to disable all checks on the server, then enable them when we were done (DISABLE_HOST_SVC_CHECKS and ENABLE_HOST_SVC_CHECKS). The enable portion of this caused the passive checks to enable their active checks, even if the configuration files had " active_checks_enabled 0".
This could be checked by going to the advanced section of the checks and seeing that the active checks were enabled. When we turned off active checks, everything worked properly again.
